Thread: heater pipe that attaches to the thermostat housing .. what sealant to use ?
Results 1 to 16 of 16
  1. #1 heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    Hey guys,
    So I'm stumped here, there is a small metal pipe that comes off of the back of the thermostat housing that further leads to one of the heater hoses. The end of this metal heater pipe that goes into the thermostat housing has an O-ring seal. My question is .. is there anything else that holds this heater pipe in place? .. the reason why I ask is that in my 2001 Grand Prix SE, this pipe keeps coming off under pressure when car is running, I was wondering what Pontiac uses to seal this pipe in place. Does anyone know? .. please help
  2. #2 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Just the 10mm bolt.
  3. #3 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    bolt huh? .. I think I found my problem then, my heater pipe is just a pipe without any bolts holding it .. do you have a picture of bolt/plate, or better yet a picture of the correct pipe to use ?
  4. #4 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Hold on..into the stat housing..not the front passenger side of the head...uh..
    I think into the stat housing it's threaded. Into the front right is bolted.
    No..I wouldn't infect my photobucket with pics of 3100's...sorry.
  5. #5 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    GT Level Member ShadowSwept's Avatar
    Kentucky
    LOL. Wow.
    Earliest I could get you a pic is tomorrow . My recollection is that both ends were bolted, but it's been a while so I don't know. Try an image search.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  6. #6 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    thanks for your help .. does anyone else want to pitch in?
  7. #7 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    Quote Originally Posted by ShadowSwept View Post
    LOL. Wow.
    Yeah, a pic would be great, thanks
  8. #8 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    CTRacer... send him a pm. He likely has pics or can get some quick.
  9. #9 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Pennsylvania
    We talking about this part?
  10. #10 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    yes, looks like it ,, is there a bracket that is welded onto that pipe ?
  11. #11 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Pennsylvania
    BAM!
    So that bad boy should be bolted to the head.
    "heater inlet pipe"
    Torque to 25 NM, 18 LB FT.
    I wonder if it needs a quick-disconnect threaded into the lower intake? Maybe this guy? Poke your finger in the hole and feel for threads.
    Check out part 531 here. If that's your guy, then it can probably be had cheaper by searching for part #10189218
    Okay, think I'm spent.
  12. #12 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    yup, that's the part I'm looking for, but that part number that does not fit my 2001. Do you have the right part number for my car ?
  13. #13 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Pennsylvania
    May have to hit a dealership up. I'm afraid the google doesn't know.
    Register and search http://60degreev6.com.
  14. #14 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    thanks for your help man
  15. #15 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Pennsylvania
    Worst case scenario, mark it while installed and weld a piece of sheet metal to it. Or epoxy.
  16. #16 Re: heater pipe that attaches to the thermostat housing .. what sealant to use ?
    Boston, MA
    The guys at my local dealership were of no help.
    So I was able to find a picture of the part that I'm looking for and the actual name of the part, but still need a part number.
    The part is called heater inlet adapter pipe (it's the black metal pipe) and goes into the intake manifold as pictured, with the other end going into the inlet heater hose.
    Can anyone help with the GM part number?
    Here's a picture ..
  1. Thermostat housing gaskets
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2011, 03:54 PM
  2. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  3. thermostat housing bolts stripping my sockets..help!!!
    By dmahlikGT in forum General Tech Discussion
    Last Post: 10-16-2010, 03:34 PM
  4. Replies: 8
    Last Post: 10-05-2010, 08:57 PM
