Thread: How hard is it to change the thermostat out of its housing???? (3.1)
Results 1 to 9 of 9
  1. #1 How hard is it to change the thermostat out of its housing???? (3.1)
    Nov 2009
    Louisville, KY
    I found a nice write up on how to access the housing just not sure if there are any little tricks for getting it out that you guys might know
    i.e do I have to remove the exhaust crossover pipe.
  2. #2 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Virginia
    It's not hard, quite fast to.
    GEt the haynes book
  3. #3 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Nov 2009
    Louisville, KY
    yeah i got the haynes but it didnt help because the pics sucked, but i got it done. The crossover pipe and heat shield were a beast
  4. #4 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Virginia
    Yeah, we had to change the head gaskets, and that was a *****.So we just replaced every gasket in the car. 4 day process, 1 day taking apart, a full day of cleaning.and a day and a hafe of putting it back apart.I learned alot
  5. #5 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Apr 2009
    stockton ca
    Get on gpona.com sign up and they have the si200 gm service program
    As far as the tstat housing goes its easy as pie just need a catch pan for coolant and a socket and wrench and 10 minutes time
  6. #6 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Virginia
    Is it hard to change the radiator in a 96?se?
  7. #7 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    catch pan.. haha
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  8. #8 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Nov 2009
    Louisville, KY
    Yeah, I manage to get it done i was just the pesky exhaust crossover pipe who's bolts were rusted in. Thanks for all your help
  9. #9 Re: How hard is it to change the thermostat out of its housing???? (3.1)
    Las Vegas
    Quote Originally Posted by justjones View Post
    I know this is an old thread, but I just did this. The thermostat housing is behind this exhaust pipe and there is no clearance. Not very car savvy, took me a couple hours. Crappiest part was getting the second bolt back in.
  1. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  4. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
