Thread: 1994 no cooling fans
Results 1 to 6 of 6
  1. #1 1994 no cooling fans
    Nov 2011
    ND
    Have 3100 and the coolings don't operate. Jumped the harness by the sensor and fan come on for a second and then kick off. Disconnected both fans and put a test light in both fan motor harness connectors, same result fans should be OK. Replaced the relays - same problem. Harness by the sensor plug in doesn't look the best and goes underneath the intake so I don't know the condition. Any thoughts on why the fans won't operate?
  2. #2 Re: 1994 no cooling fans
    Omaha, NE
    Coolant temp sensor?
  3. #3 Re: 1994 no cooling fans
    Nov 2011
    ND
    I jumped the two wire sensor by the thermostat. Shouldn't the fans start running when that is done?
  4. #4 Re: 1994 no cooling fans
    Nov 2011
    ND
    Can anyone give me any info on the wiring of the temp sensor thru the relays to the fan?
  5. #5 Re: 1994 no cooling fans
    those things arnt connected the computer is between them
    SMGPFC Member #10
  6. #6 Re: 1994 no cooling fans
    Nov 2011
    ND
    OK - thats what I was trying to get at. Maybe a I have a ECU problem?
  1. Cooling fans issue
    By yetisn0wman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2011, 09:53 AM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. 1994 gtp cooling fans not working
    By almighty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-01-2010, 09:39 AM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
