I have a 2000 Grand Prix SE w/3.1L. I'm attempting to move the power steering pump out of the way in order to replace the camshaft position sensor which is underneath it. I removed the 3 bolts mounting bolts for the power steering, but when I attempt to move the pump out of the way, it hits metal to metal. If I attempt to slide it toward the firewall in order to clear the C shaped mounting casting, I'm constrained by the bank 2 fuel rail. In order to remove the power steering pump, must I first remove the upper intake and bank 2 fuel rail and injectors?
Thanks!
