Thread: cooling fan switch
Results 1 to 3 of 3
  1. #1 cooling fan switch
    Aug 2011
    Florida
    hey i am wiring a switch for my low speed cooling fans through the relay. so the switch i have is a lighted switch and say neg, acc, pos. my wires coming from the relay one is always hot. so i assume to plug the wire thats always hot into the postive, the other wire coming from the relay that isnt hot into the acc, and the negative i just wired a ground from the ebrake bolt. so i am able to hook everything up and it was working but the i noticed the light went out and it ended up blowing the cooling fans 30 amp fuse which was like 4$.
    also it was working fine when i would just connect the two wires manually from the relay for a while without blowing any fuses, so it seems that the ground is letting battery voltage to the cooling fans circuit or something, if anyone knows anything let me know.
  2. #2 Re: cooling fan switch
    Aug 2011
    Florida
    40 views and not 1 reply, come on someone
  3. #3 Re: cooling fan switch
    whats the question?
    cant get the relay to work right
    SMGPFC Member #10
  1. Cooling Fan Switch location?
    By shaner in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-22-2012, 10:15 AM
  2. Hi Lo cooling fan switch
    By 91z in forum General Tech Discussion
    Last Post: 06-17-2011, 07:16 PM
  3. cooling?
    By jerrysalley in forum General Tech Discussion
    Last Post: 08-18-2010, 11:36 AM
  4. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  5. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
