Where do you tap into these engines to check oil pressure or hook up a gauge.
just past the oil filter is a sensor, thats the oil pressure sensor, remove it, and screw in a after market gauge, or put a T on it and run both sensors if you like.
Mine is a 98 so pressure sensor is in a different location,i found it but thanks for the help.
OP has a 3.1.
The picture is for a 3.8.
