1995 grand prix se 3100 sfi V6: 182,000 miles
Problems:
-Idle is irregular, flutters between 800-1000 rpm, but doesn’t stall
-Car slips (or surges or whatever) when holding a constant speed but only when the speed is above 45mph
-Car runs like a top when you are just driving around town and keeping the speed below 40mph
Items that have been replaced:
-Battery
-Alternator
-Air Filter
-Oil Filter
-Oil
-Spark Plugs
-Wires
-Cam Shaft Position Sensor
-Throttle Position Sensor
-Map Sensor
-Blown Fuel Injector Fuse
-Brake Pads
-Rotors
-Cleaned Throttle body, IAC, and pathway (in the upper intake plenum) leading to EGR, as well as the EGR itself.
Ideas of what the problem is:
Most likely:
-Oxygen Sensors
-Fuel Filter
-Fuel Injector
-Vacuum Leak
-Crank Shaft Position Sensor
Least likely:
-EGR
-IAC
-Ignition Coils
-ECM
Any suggestions on where to start troubleshooting?
