I'm looking for the OEM recommendations for the various fluids for my 96 GP SE.
Power steering fluid - What type? How much of it will I need if I'm flushing the bugger?
Transmission fluid - What type? How much do these trannies hold? I don't even know what transmission this is, so if someone could clarify, that would be awesome. I like that I can lock it into all of the lower gears - My ford is a 4 speed with 1-D-OD so not a lot of options there. I've a question about the gear selection in this, though - Is it a 4 speed with 4th an OD? Can you engage and disengage the OD manually? for trips up hills etc I don't like to have a transmission hunting between OD and D gears.
Brake - DOT3?
Coolant system - This is where the controversy is going to be. I don't know if it's been a Dexcool car its entire life or not.
Should I wait and see what coolant is in it before I buy more? The car will be home today, hopefully.
Should I keep running DEX? I'm told it's gotten better since the intake manifold fiasco but I thought I'd ask you guys since this place seems to know what's up.
thanks guys!!
