Thread: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
Results 1 to 11 of 11
  1. #1 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Tilton newfoundland
    I have a 1996 Grand prix that recently lost the motor, the body is in impeciable condition and i really dont wanna thow the body away, With that said I also have a 1991 Grand Prix 3.1 with and excellent running engine and trans but the body is toast. Is the Motor from the 91 a direct swap into the 96? The motor and trans seem to be the same to bolt in but my concern is the wiring hooking up fine without making a mess of a harness. Any input would be greatly appreciated.
  2. #2 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    it sould fit in the same holes as ur 96. its the same set up, just diffrent year cars.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  3. #3 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Tilton newfoundland
    I figured it would bolt in the same but my concern is the wiring. I thought possibly that the 94/95 model may have variences in the wiring from the 91/93 models. Thats my main concern
  4. #4 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Moore, Oklahoma
    If you're concerned about the wiring, just swap all the sensors from your '96 engine into your '91 engine.
  5. #5 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Tilton newfoundland
    But are there any extra sensors on the newer car that the the older engine do not have the hook ups for? Or anything on the harness that wont directly connect to the engine?
  6. #6 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Moore, Oklahoma
    Interchange: 1991–1993 models were Multi-port injection, and had a single crank sensor for computer timing. 1994-1995 models used the same long block, but had different cam carriers and timing cover. 1996–1997 models used a modified version of the same short block and had different heads. 91-93 motors cannot be used in later models due to lack of sensors needed for the newer computer systems. (Found on Wikipedia, GM 60-Degree V6 engine)
  7. #7 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Moore, Oklahoma
    If you could find a 94 and up 3.1 it should work.
  8. #8 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    May 2011
    Tilton newfoundland
    With that said is it possible to use the computer from the 1991 in the newer car to make it run correct?
  9. #9 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    SE Level Member GPmanter's Avatar
    Nov 2011
    Reynoldsburg, Oh
    I'm rather new here but I would have to say anything is possible but sounds like it might be a lot of time & effort to switch over the computer & harness, as well as anything else you would have to swap over.
  10. #10 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    Topeka, KS
    Swap a L67 into it, TURBO, and Enjoy
  11. #11 Re: 1991 grand prix 3.1 swap into 1996 grand prix 3.1
    Nov 2010
    Ray MI
    A 96 is a 3100 OBDII while a 91 has a 3.1 with a OBDI system. Lot's and lot's wiring to get it work.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  1. 1996 Grand Prix
    By The LoKi in forum Introductions/Noob Questions
    Last Post: 05-18-2010, 06:12 AM
  2. 1991 grand prix starts then dies after five minutes
    By oithebusiness in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2009, 12:54 AM
  3. 1991 Grand prix issues- HELP ME
    By Fastline42 in forum General Tech Discussion
    Last Post: 06-25-2009, 02:20 PM
  4. 1991 grand prix od?
    By thenervemann in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-13-2009, 02:25 PM
