Thread: Not starting- no spark, no fuel pump
Results 1 to 13 of 13
  1. #1 Re: Not starting- no spark, no fuel pump
    Hoffman/Schaumburg, IL
    If I remember correctly, the fuel pump turns off after 5 seconds if the engine isn't running, It judges if the engine is running by the signal from the CPS(through the PCM i Believe). So check your CPS and all the wiring to it cause that would cause the pump to run for no more than 5 seconds and no spark
    Hope that helps
    Edit, or also possible, failed ICM wont let the CPS signal through to the PCM (CPS signal runs through the ICM to get to PCM) thus causing fuel pump to stop running and no spark(from failed ICM)
  2. #2 Re: Not starting- no spark, no fuel pump
    Quote Originally Posted by 02BlueGT View Post
    Hope that helps
    Where is the ICM located? I am used to them being at the coil pack, but can't find it.
    Going to take out the icm and test it, as it is 80$, and if it is good, change the cps for 25, and see if that helps.
    There is no fuel pressure in the line, making me wonder if it is even coming on for 5 sec.
    Thank you for the help.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  3. Fuel Pump?
    By 03BCprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 11:59 PM
