Thread: smelling fuel.
Results 1 to 4 of 4
  1. #1 Re: smelling fuel.
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    dunno the tank size but the smell could be evap emissions, maybe an injector o ring, fuel line connection, look for leaks, smel for leaks. if the evap emissions fail there should be an engine light. even a bag gas cap can cause the smell and usually sets an evap code service engine light
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: smelling fuel.
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Only reason i wouldnt say cap is because i just got that code for cap not being tightened. My old car had the same prob came to find out it was the fuel injector
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
