Bottoni70
Ok, I am really getting frustrated with this.
The car's Temp will jump around a lot, it will range from around 180 all the way up to the red 265. The hotter the temp the lower the heat I have. If I give it gas, it will quickly move down to normal and I have heat again.
I have replaced the following:
Radiator
water pump
thermostat (stock temp)
Radiator Cap
upper and lower intake gaskets
full coolant flush (with Prestone super clean)
It acts like there is quite a bit of air in the system, but when I get it up to temp and I open the bleeder valve a lot of air comes out and feels like it will not stop, I've tried bleeding for about an hour (opening and closing) and air still comes out.
The fans kick on at the right temp, low and high
when they do kick on the air coming off is fairly cool, but if I give it throttle then the coolant will start flowing and the temp will come down and good heat will come off the fans.
Not leaking coolant anywhere, none in the oil and no white smoke.
I don't know what to do next!!??
any help would be greatly appreciated
