Thread: The purge sensor question
Results 1 to 3 of 3
  1. #1 The purge sensor question
    minnesota
    So i got everything going fine on the 96 grand prix except one thing now it idles real poorly. I have a scanner so i put it on there no codes were present but i played around in the functional test and when it got to purge sensor i flipped it on and it idled smoothly but soon as i take the scanner off it goes back to normal. Pretty much saying the sensor is back off.
    Any ideas? Is it broke or is it not acting right from something else?
  2. #2 Re: The purge sensor question
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    its posible the purge sensor is bad, or a vacuum leak, i dunno usually idle problems are idle sensor, or mass air on ur 96, o2 can idle funny too but seems like u would get a code, had a 96 lumina with a bad idle sensor, didnt give me a code, i changed it and perfect.
  3. #3 Re: The purge sensor question
    minnesota
    Yea i was seeing if there was a broken hose or one that had fallen off. I unhooked the mass air flow sensor and it idled smoothly. So it may be that.
  1. Front Knock Sensor Removal Question
    By nickbuol in forum General Tech Discussion
    Last Post: 07-23-2009, 08:22 AM
  2. Question about a MAF sensor.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 08:45 PM
  3. Sensor question,,,,,,I think
    By the955iman in forum General Tech Discussion
    Last Post: 04-22-2009, 04:14 PM
  4. MAF sensor question
    By Black2000GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2009, 07:06 PM
  5. o2 sensor question
    By TJs97 in forum General Tech Discussion
    Last Post: 06-22-2008, 09:26 PM
