Thread: Irratic RPM's at cruising speed (40-60mph)
Results 1 to 3 of 3
  1. #1 Irratic RPM's at cruising speed (40-60mph)
    Jun 2014
    camano
    Doesn't seem serious but it is annoying. warming or warmed up my 2002 GP SE 3100 surges 2-3k rpm's when at cruising speeds. If I kick it into 3rd from drive it goes away. It seems like if it's "lugging" even a little it will start jump around (at about 2k rpm's). Other than this issue, at 145k miles it's one of the nicest running cars I've had in the past decade. Any advice or suggestions will be appreciated.
    Thanks
  2. #2 Re: Irratic RPM's at cruising speed (40-60mph)
    over dive kicks in at 45 mph, if your light on the gas it sounds like the 4 th hub is taking a crap.
  3. #3 Re: Irratic RPM's at cruising speed (40-60mph)
    GTP Level Member Rlugo87's Avatar
    Jun 2016
    Minnesota
    My 01 gt was doing the exact thing at 131k nothing short of a rebuild fixed it.
    Sent from my XT1609 using Tapatalk
  1. Engine surges intermitently at cruising speed
    By ktownman75 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2013, 01:19 PM
  2. GTP shakes between 40-60mph
    By quigs in forum Brakes/Suspension/Chassis
    Last Post: 02-13-2012, 10:28 PM
  3. irratic bogging while normal downshifting
    By Jrs1987 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2011, 07:47 PM
  4. irratic idle in drive while warm
    By Lord4play in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2011, 09:52 PM
  5. Shaking Between 40-60MPH while Throttling
    By nathangartz in forum Tires & Wheels
    Last Post: 08-10-2009, 04:23 PM
