Curious when scanning what is an acceptable amount , if any , of tcc slip? While cruising or under wide open throttle ?
I don't think I let it shift into 4th under wot but I will check my 4th locked slip. Thanks !
Well you wouldnt want to shift into OD at full throttle anyway.
But while locked in 4th on the freeway, slip should be very very small or none at all.
Yeah lol I know that
I was just concerned at the top 3rd wide open I though I saw slip rpm show up
I was showing about 1650 taking off normally and locked up in 4th gear was about 20-30 rpm. I'm curious about this too and was going to ask the same thing. Under full throttle launches I would see a peak of 1950 or so.
Jeff
Slip depends a lot on the lockup strategy and converter clutches. Then factor in all the other various items the pcm sees and you end up with a little slip here or there depending on what is going on.
pcm will command anywhere from 0 to 150 rpm slip depending on the load at tcc "apply"
its mainly to minimize NVH and isnt used on my crap, i set lockup to 100% duty cycle and deal with the "5th shift" and sometimes the lugging vibration at low rpm's in 3rd/4th (where you can almost feel the individual cylinders firing
Very strange issue here as well. The more you dig into the throttle while the convertor is locked , I occasionally would see 1-2* kr before it would release. Now you can adjust it to release early but I kept it the same because something odd happened.
Once I filled the intercooler and ran it, it never came back.
What do you mean by "something odd"?
I told you the "odd" part - once I filled my IC and ran it, it never came back.
https://www.dropbox.com/sh/npa8brtuzoq3qps/jqYuBP0cv- love that trans tune. but you have no perf shift button, so you have to move the perf shift files to the normal files .
Hmmm, not odd to me I guess. Pretty much expected.
Well odd to me cause tbere was hardly any boost coming from the blower.
which leads me to another question about PE. I can make boost under certain conditions before entering 40% throttle which is what my PE is set to - so 1-3lbs at a stoich AFR no kr .... Again all with the apply / release tables and why I dropped 3rd lock up all together.
Scorty those hose files for 3.29s?
if you have your tranny wroked like one of them valve bodys, use the trand file from bills regal.
if not theres another one in his name folder, or i could email you a bin with the trans tune to keep the searching down.
I'll be home at noon thirty today and will look at it if you want to send it
thanks!
Load trans settings
Search on the usual BillBoost "ea sy" and then adjust for 3.29's.
Ohhhh the 10 min this might take. It's painful
