Thread: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
Results 1 to 12 of 12
  1. #1 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Jul 2015
    Tampa, Fl
    2000 GP/GT 3.8 under hard throttle -rev limiter kicks in- preventing cylinders from firing thus engine runs rough -only happens under full throttle. Thought maybe need new flash to computer
  2. #2 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    maybe your tranny is slipping like a muther? what your rpm's when the limiter kicks in?
    or are you flooring it in park, and it cuts out? if so thats normal.
  3. #3 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Under hard throttle at what RPM? are you actually hitting the rev limiter or what rpm does it do this? I don't get your issue. Need more info.
  4. #4 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Oct 2011
    Toledo, OH
    I think Scotty nailed it. Trans is starting to go.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  5. #5 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    not enough info to just assume trans is going out.....
  6. #6 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Kemmerer, Wyoming
    I think the guy wants to go faster than 120
  7. #7 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Jul 2015
    Tampa, Fl
    Quote Originally Posted by Bill Blair View Post
    Thanks for all the reply's -I'm posting this for a friend who doesn't have internet service(shame on him!) By the way he is a 20+ year mechanic -BUT not a tranny tech -this is his wife's car -he is driving trying to figure out what's going on, The rev-limiter kicks in @ 4500 rpm
    below 4500 rpm the tranny shifts OK - so the car is drivable -as long as you don't get on it! Even with his mechanical background -he is stumped
    thanks again for all the input
  8. #8 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Jul 2015
    Tampa, Fl
    Quote Originally Posted by 98bleedingaholevet View Post
    see latest post
  9. #9 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Jul 2015
    Tampa, Fl
    Quote Originally Posted by ScottyDoggs View Post
  10. #10 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Apr 2015
    Columbus, OH
    The rev limiter is programmed into the pcm. Dont see how that would suddenly change. You have other issues, possibly ignition related but hard to say without knowing exactly what its doing. Could be as simple as plugs/wires.
    Top Swapped 01 Imp
    VS (very small?) cam, SD Headers, 2.8" pulley, 29°, ported everything, E85, AEM water/meth, Deka 60's, HPT tuned
  11. #11 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    if a 20+ year mechanic cant figure out it needs a tune up, oh boy o boy.
    ask the guy if the check engine light flashes when he floors it. that means misfires, clogged cat, or its in need of a tune something fierce.
  12. #12 Re: 2000 GP/GT rev limiter causes computer to cut off clyinders from firing
    Kemmerer, Wyoming
    maybe its one of those things where the spouse is saying: "honey my car is broke." and the mechanic asks: "what is wrong with it?" and the reply is something ambiguous.
  1. 2000 Pontiac Grand Prix GT 3.8 firing order
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2013, 09:55 PM
  2. not firing
    By jlt in forum General Grand Prix Discussion
    Last Post: 02-07-2012, 07:42 PM
  3. still not firing
    By jem0103 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2009, 03:48 PM
  4. not firing
    Last Post: 07-06-2009, 06:24 PM
  5. 06 gp not firing on 2-4-6 cyl
    By melnrob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2009, 05:19 PM
