Thread: passenger side clunk axel or differential
Results 1 to 19 of 19
  1. #1 passenger side clunk axel or differential
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    This clunking ive been having between my LS and GS Regal has pushed me to believe its either the axel or differential.
    I've changed the axels numerous times and now they're GM axels, transmission was rebuilt a lil over 3yrs ago. All other suspension components are less than 2yrs old.
    So between the diff and axel on the passenger side which is more likely to make this clunk noise? You here it in reverse or drive when taking off or simply just at a stand still switching from reverse or drive.
    No play with none of the motor mounts, all are good
    What chal think?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Differential making the noise or the axel itself?
  3. #3 Re: passenger side clunk axel or differential
    Apr 2015
    Columbus, OH
    Have you jacked it up and checked for play? These trannys seem to have a lot of slop anyways, but I would try to find the noise with the front on stands. You said you replaced the axle numerous times so you can probably rule that out. Maybe the drive chain is stretched? Guess it could be the diff. They aren't hard to swap if you can pull one at a yard.
    Top Swapped 01 Imp
  4. #4 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Tranny is only 3yrs old, it was rebuilt but im not sure if a differential is a component that is usually replaced when rebuilding a tranny(im not sure if its a definite component that gets changed or if it depends on whether its bad or not)
  5. #5 Re: passenger side clunk axel or differential
    Have you checked your subframe bushing bolts to ensure there's no play there? As well your strut tower mounts are good and the spring rubbers are not worn?
    These are more likely than a diff.
  6. #6 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Subframe bolts are good and tight(mounts 2yrs old)
    Strut mounts are a lil over 3yrs old installed them when i did the new struts. I suspected the strut mounts too, but the wierd thing is that it only happens when changing gears or from a dead stop & go and reverse.
    Funny bc both my regals are making the same noise on the passenger side and it has nothing to do with the motor mounts or dog bones.
    Differential has to have some play or this $400 GM axel has gone bad and or has play already
  7. #7 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Just checked strut mounts and they're good......in fact whole strut assembly is in good shape
    Gotta be differential or axel. What are the chances of it being the differential?
  8. #8 Re: passenger side clunk axel or differential
    Apr 2015
    Columbus, OH
    I would say slim. Its not like a rwd where it clunks if you don't have lash set right. They usually work fine or they shatter. Sway bar broke?
    Edit: if you still think it is diff, pull one from a yard and swap it in. When you did axle you were only about 7 bolts from it.
    Top Swapped 01 Imp
  9. #9 Re: passenger side clunk axel or differential
    You know what most say about Bill's advice...
  10. #10 Re: passenger side clunk axel or differential
    Apr 2015
    Columbus, OH
    Yeah, they say Bill's advice is legendary and should be engraved in stone tablets and put in front of every courthouse in the US....least that's what I've heard.
    Top Swapped 01 Imp
  11. #11 Re: passenger side clunk axel or differential
    Or I get lucky and am right more often than most..lol
  12. #12 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Bills advice is the shizzzzznet......
  13. #13 Re: passenger side clunk axel or differential
    Remember that air bag light you had...
  14. #14 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Well if its the axel again then even the GM axels aren't tough enough. I need a hardcore axel
  15. #15 Re: passenger side clunk axel or differential
    It's not your axle..
    Because I didn't suggest that.
  16. #16 Re: passenger side clunk axel or differential
    Apr 2015
    Columbus, OH
    Lol, I think you were just b1tch slapped by Bill.
    Top Swapped 01 Imp
  17. #17 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Not my axel? Wtf, so my differential?
    Oh and about the airbag light, continues to come on never really stop even after the lil trick reset i did
  18. #18 Re: passenger side clunk axel or differential
    5 times is what it takes..maybe a little dielectric.
    I never said diff. I said ... mmm suspension related
  19. #19 Re: passenger side clunk axel or differential
    Jul 2012
    North Philly
    Right, but u also said its not my axel. Suspension is totally fine, theres nothing underneath with that much play to allow this clunk that im getting from a dead stop or just putting it into drive or reverse(only coming from passenger side
  1. clunk in front end when turning wheel side to side
    By ronaldgtp in forum General Tech Discussion
    Last Post: 12-12-2021, 07:14 PM
  2. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
  3. driver's side loud clunk when turning wheel either way!!!
    By Doug 97 gtp in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2012, 10:36 PM
  4. Loud clunk in driver side rear
    By MizzBecca in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2012, 05:44 AM
  5. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
