Thread: Can I still put a Transgo shift kit in?
Results 1 to 11 of 11
  1. #1 Can I still put a Transgo shift kit in?
    GT Level Member Jonarin's Avatar
    Oct 2014
    I just recently dropped my tranny pan and cleaned and replaced my filter as well. Everything went well but I never put the shift kit in. Would I be able to drop my pan (again) and keep the filter in, take out what I need to take out for the shift kit and put it back together? Would I have to change the gasket again? And I would obviously get new fluid once again.
  2. #2 Re: Can I still put a Transgo shift kit in?
    Dec 2013
    ohio
    Filter should be good and fluid, if it never got hot, should be fine too as long as you keep it clean. Gasket I wouldn't chance but that's just me.
  3. #3 Re: Can I still put a Transgo shift kit in?
    Kemmerer, Wyoming
    supposedly the oem gasket are reuseable for the trans pan. if you can drain your trans fluid into a clean reservoir its probably reuseable, as well as the filter.
  4. #4 Re: Can I still put a Transgo shift kit in?
    GT Level Member Xorbex's Avatar
    Canada
    I reused stock gasket and no leaks yet.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  5. #5 Re: Can I still put a Transgo shift kit in?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    ^^X2 on both the previous posts. You could have reused your stock gasket if it was in good shape. But with the replacement one I would be leery.
    If it looks good though I would reuse, cause i'm a gambler. Same with the fluid. If it looks ok, and hasn't been run, go with it.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  6. #6 Re: Can I still put a Transgo shift kit in?
    Oct 2014
    I've driven my car for about 50 miles already though
  7. #7 Re: Can I still put a Transgo shift kit in?
    You can clean down the pan area as best as possible. Use a super clean catch pan and reuse fluid. Filter .. reuse it. Gasket.. did you use the crappy rubber pos that comes with the kit or did you reuse the stock gasket with the metal inlaid in it?
    50 Miles.. personally.. I'd reuse it all. But you better strain that fluid and make super sure you don't put dirt into the trans. Although.. it'll just end up in the filter.
  8. #8 Re: Can I still put a Transgo shift kit in?
    Buffalo
    I just got the intense shift kit in the Mail. Very impressed with the detailed booklet and all the included parts, lube, sandpaper , green pad etc. awesome deal and very well put together. +1 to intense
  9. #9 Re: Can I still put a Transgo shift kit in?
    Oct 2014
    I used the rubber crap one that came with the kit.
  10. #10 Re: Can I still put a Transgo shift kit in?
    sorry to hear that
  11. #11 Re: Can I still put a Transgo shift kit in?
    SWPA
    My question is, WHY did you not put the kit in when everything was apart. All you did was made more than double work for yourself.
  1. LF: Transgo Shift Kit
    By blackthunder in forum For Sale - Parts
    Last Post: 07-10-2014, 11:19 PM
  2. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
  3. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  4. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
