Thread: Install a shift kit while i change filter??
Results 1 to 7 of 7
  1. #1 Install a shift kit while i change filter??
    Feb 2014
    Grand Forks, North Dakota
    So my transmission has about 135k mi on it. The fluid is brownish red but more brown. I was just going to do a pan drop and filter change, but thought when Im at it should I install a transgo shift kit? Right now the tranny shifts good, no slipping etc. I dont think the fluid has ever been changed before I owned the car. Just wondering your guys opinions. I'm not going to be doing much modifications maybe just headers. So I wont be beating the piss out of it.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: Install a shift kit while i change filter??
    Mar 2012
    NC
    Now would be the perfect time to do it. It'll help the stock trans last longer.
  3. #3 Re: Install a shift kit while i change filter??
    Jul 2010
    Coquitlam,BC,Canada
    Yes, install one.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Install a shift kit while i change filter??
    Mar 2014
    Tucson
    I put the trans go kit in mine. Wasn't having any issues either. I just considered it preventative maintenance on a higher mileage trans. Along with a new filter and fluid.
  5. #5 Re: Install a shift kit while i change filter??
    Feb 2014
    Ok. I suppose ill put one in. I just wasn't sure with having that many miles without a possible fluid or filter change and it being brownish as well.
  6. #6 Re: Install a shift kit while i change filter??
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Absolutely, I had great luck with mine. Added an external cooler at the same time as well.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Install a shift kit while i change filter??
    GTP Level Member
    Aug 2012
    st louis park, MN
    I opted for a shift kit and cooler along with fluid and filter on my car.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. Hard Shift After Fluid/Filter Change
    By Chadgervais in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2013, 09:59 PM
  2. Pan drop and filter change.
    By Bluemagic in forum General Tech Discussion
    Last Post: 04-04-2013, 02:43 PM
  3. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  4. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  5. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
