Thread: Transmission weight
Results 1 to 16 of 16
  1. #1 Transmission weight
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Does anyone happen to know the weight of a 4T65eHD transmission full of fluid with Diff? Im picking one up friday and i need to know if ill need the cherry picker or not
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Transmission weight
    Jan 2014
    AR
    My friend picked up mine (no fluid but complete) from the back of a Dakota and walked it into my back yard for me, by himself. I'd say under 200 lbs. Two guys no prob.
  3. #3 Re: Transmission weight
    Apr 2014
    South Haven, MI
    That makes me feel a little better lol. It should be no problem then. Thank you
  4. #4 Re: Transmission weight
    Mar 2014
    Tucson
    Full of fluid + torque converter? Pickable by hand, but definitely a 2 man job.
  5. #5 Re: Transmission weight
    Dry no converter is 160lbs.
  6. #6 Re: Transmission weight
    Enfield, CT
    Picked up a 4t60, that was half full of fluid and removed the converter, right off the garage floor and threw it into the bed of a ferd f-onesh!tty. Just pushed it off the bed onto the ground at the scrap yard lol
    Sent from my LG G3
  7. #7 Re: Transmission weight
    bill and i humped my old tranny into the back of his truck. i took the heavy side, and bill said a tranny never felt so light with me on the other side lol
    if need be, i could hump it into the back of a truck solo, converter and all. i also pulled a short block off the stand, put it on the floor, then humped it back on the stand. solo. so im a good grunt when need be lol
  8. #8 Re: Transmission weight
    I've hefted transmissions (still full of fluid) out of GP trunks alone. Shortblock.. ehhhh I've learned my lessons, that's what hoists are for.
  9. #9 Re: Transmission weight
    i failed to own a hoist at that time. i took it off to do the rear cover. flipped it over, then put it on a tire. the cylinders make nice hand holds.
  10. #10 Re: Transmission weight
    I made a notch in my trans support bracket.. so I could put the hook in the exact spot of balance every time.
    I should sell that bracket for big moola.
  11. #11 Re: Transmission weight
    Mar 2014
    Tucson
    How much "moola" we talking about here?
  12. #12 Re: Transmission weight
    Enfield, CT
    Hmmm this is good to know lol
    Sent from my LG G3
  13. #13 Re: Transmission weight
    Joo wanna borrow? I think it's in the shed
  14. #14 Re: Transmission weight
    Mar 2014
    Tucson
    Naa. I have at least two trans build/installs in the future, so I would need it long term.
    BUT... I would be very much interested in some pictures with measurements.
  15. #15 Re: Transmission weight
    Buffalo
    Quote Originally Posted by idrivejunk View Post
    F that bs. My trans felt like a fat pig. I slid it around on a pallet most of the time but still - f trying to carry it!
  16. #16 Re: Transmission weight
    Buffalo
    that was another fun venture - tying to balance the trans. Good to know for future reference if I ever take it out through the top again
  1. Weight Loss or Weight Gain Thread "2012"
    By benner in forum Off Topic Discussion
    Last Post: 08-24-2014, 12:27 AM
  2. Wheel weight
    By Performance nut in forum Tires & Wheels
    Last Post: 02-28-2013, 03:34 PM
  3. how much does your car weight
    By Seachicken in forum Off Topic Discussion
    Last Post: 02-03-2013, 09:45 PM
  4. PAG Weight
    By vertebrate in forum General Tech Discussion
    Last Post: 08-07-2012, 05:02 PM
  5. Rim Weight
    By DPs98GTP in forum Off Topic Discussion
    Last Post: 05-01-2010, 07:28 PM
