Thread: Shift kit and "hard part failure?"
Results 1 to 13 of 13
  1. #1 Shift kit and "hard part failure?"
    Mar 2015
    Connecticut
    The usual consensus on shift kits seems to be, they cause less wear on the transmission than OEM, and OEM only makes transmissions shift "smoother" because most consumers expect that.
    Then I read this on ZZP:
    "Shift kits can increase the chance of hard part failure but they do keep the clutches from slipping and burning."
    Hmm... I would think "hard part failure" repairs could get more expensive than replacing clutches. Am I wrong?
    So if the goal is long-term reliability, does a shift kit really make sense? Or is the chance of hard part failure so small that it's still better to use a shift kit and save the clutches?
  2. #2 Re: Shift kit and "hard part failure?"
    I wouldnt be worried about any failures. Perhaps if you made some decent power and used the Intense shfit kit on the hardest setting and you beat the piss out of the car alot, then a failure could become an issue.
    I'd recommend the trans go shift kit over anything. They do far more good than bad. Increased/faster shift times do help the wear on the clutches and the trans go kit is not harsh at all.
    I personally have the ablity to custom tune my PCM and increase the shift times and pressures even further and it's not a cause for concern on a healthy transmission. Hard parts could break at anytime but it's mainly do to more power being added.
  3. #3 Re: Shift kit and "hard part failure?"
    Buffalo
    The stress added to the stock input shaft comes to mind .....
  4. #4 Re: Shift kit and "hard part failure?"
    Mar 2015
    Connecticut
    Quote Originally Posted by crazyguy03 View Post
    Do you think that's a concern even with a completely stock engine? I thought the stock input shaft was good for up to 300whp.
  5. #5 Re: Shift kit and "hard part failure?"
    Buffalo
    Nope Never had an issue until I cam'd it.
    From Stock to rockers and intercooler with 3.0 gen5
    it was the cam that broke the camels back , twice... Before I went to a 300m
    but im sure there is 100'different opinions
  6. #6 Re: Shift kit and "hard part failure?"
    Jul 2010
    Coquitlam,BC,Canada
    This is a general term. Doing almost anything to your car will change how it acts/performs/lasts/fails. The alternative to "hard part failure" is a slow shift, causing added heat, triggering the CEL, and going full line pressure. Not saying a hard part failure won't happen, but it is far and few between.
    With that being said, I am ending year 4 of having my shift kit installed. My tranny is still working the same as it was 4 years ago. The shift kit is a bandaid, so we all have to plan for a new tranny eventually.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Shift kit and "hard part failure?"
    Buffalo
    Becsuse the clutches aren't taking the abuse, it falls on the chain (stretches ) and inputshaft (snaps / breaks)
  8. #8 Re: Shift kit and "hard part failure?"
    A transgo shift kit is not going to cause hard part failure on an NA. At least...I haven't been able to cause it to lol.
    I'll take ya for a spin in the Regal and .... you'll probably install that kit quick.
  9. #9 Re: Shift kit and "hard part failure?"
    Buffalo
    Good catch. Didnt see he was n/a
  10. #10 Re: Shift kit and "hard part failure?"
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    For some of us, it actually improves the longevity of the hard parts. Not sure if you've felt a stock shift after Max Adapt, but that sure as heck can't be good for the hard parts either. The transgo shift kit is nice and firm, but not excessively so... and a whole lot nicer than the hard shift you get from shift times taking too long and triggering full line pressure.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  11. #11 Re: Shift kit and "hard part failure?"
    Mar 2015
    Connecticut
    No, I'm not NA, 2001 GTP. Anyway, just researching whether I want to add a shift kit while I'm replacing my 4th gear clutch hub, but the transmission job's taking a lower priority to replacing my LIM gasket.
  12. #12 Re: Shift kit and "hard part failure?"
    Ooopsie.. LOL
  13. #13 Re: Shift kit and "hard part failure?"
    May 2008
    Schuyler, NE
    My opinion is that everyone makes them shift too hard. So many 13 second cars snap the input shaft. Keep your shift firmness near stock, decrease shift timing, and use lots and lots of tq management during shifts. But, I only have a bunch of 11 second passes on a stock trans.
    If you're stock, I'd leave it alone.
  1. "Charging system failure"
    By FX4 Level II in forum General Tech Discussion
    Last Post: 11-25-2015, 10:52 AM
  2. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  3. How to properly reset "shift learn" or "adapt" in 4t65e-HD
    By AndrewGXP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2015, 09:30 PM
  4. Volt gauge reading high, "charging system failure"
    By Aeroheadcww in forum General Tech Discussion
    Last Post: 05-21-2014, 12:03 AM
  5. Replies: 6
    Last Post: 12-31-2008, 07:11 AM
