Thread: What kind of shift times should a 97-03 gtp have
Results 1 to 7 of 7
  1. #1 What kind of shift times should a 97-03 gtp have
    Nov 2014
    BFE,Ohio
    I bought a 00 Daytona gtp last fall and put aeroforce on it not too long ago. my question what should shift times be? They will be 175-220ms most of the time then randomly be 300-350ms
    Performance shift times don't seem to times either
    Did my post confuse you? BLAME AUTOCORRECT!
  2. #2 Re: What kind of shift times should a 97-03 gtp have
    Different factors like throttle %, torque, engine speed etc etc will determine shift times at any given time.
    The computer maybe command the 1-2 shift at say .350 but it can happen in .300 or even .400 if needed. There is a limit at some point if the shift time becomes too long that a code will be thrown.
    A custom tune could command shift times to be nearly exact all the time.
  3. #3 Re: What kind of shift times should a 97-03 gtp have
    Nov 2014
    BFE,Ohio
    OK thanks I just thought something was wrong with a random almost double shift time
  4. #4 Re: What kind of shift times should a 97-03 gtp have
    Mar 2014
    Tucson
  5. #5 Re: What kind of shift times should a 97-03 gtp have
    Kemmerer, Wyoming
    My 1-2 shift in pe mode is like .125
  6. #6 Re: What kind of shift times should a 97-03 gtp have
    Bastard Reptile's Avatar
    Kansas City, MO
    Stock shift times are long and slow compared to what people normally set them at when they tune them. The longer the shift time the smoother the shift, and more slippage/heat build up.
    Quicker shift times are snappier, and less slip/heat build up. But even on older transmissions just because you command a .1 shift time, it probably won't shift that fast simply because of the wear.
  7. #7 Re: What kind of shift times should a 97-03 gtp have
    Nov 2014
    BFE,Ohio
    Thanks all i was was curious as I was nervous about the random longer shift time.
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. 97 gtp hard 1-2 shift ( just random times )
    By justAworkingMAN in forum Introductions/Noob Questions
    Last Post: 11-03-2012, 01:00 AM
  3. What Kind of Performance Gain Expected from Shift Kit?
    By TheRoadWarrior in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-19-2012, 07:21 PM
  4. HOW many times do you shift?
    By gptrell502 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2010, 12:05 PM
  5. Stock Shift Times?
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2009, 03:11 PM
