Thread: What cv axles do I need or should I get?
Results 1 to 4 of 4
  1. #1 What cv axles do I need or should I get?
    Feb 2014
    Grand Forks, North Dakota
    I have the 40th GTP coupe that needs both axles replaced because the boots spewed their grease and do their shake under acceleration. I read on here that a couple of you guys replaced them with Napa axles. How are the Duralast reman axles from autozone? Or is there any other brands you guys know that are good.
    I also looked at the ZZP stage 1 HD axles, are they worth it or nah?
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: What cv axles do I need or should I get?
    i slapped a napa axle in there, been good for like 3 years now.
  3. #3 Re: What cv axles do I need or should I get?
    Feb 2014
    On the Napa website they have two different kind of axles according to the Important Info. One says "supplied w/ optional heavy duty." And the other type says "supplied w/ standard neoprene." Do you know which one of the two you got? I probably won't change them til early spring because its too dang cold in North Dakota right now so right now I'm just gathering options. Thanks for the quick reply by the way Scotty.
  4. #4 Re: What cv axles do I need or should I get?
    one axle is different from the other. its for a hd trans only. that maybe why. i just got a reman one for the driver side. all went well so far.
  1. CV Axles
    By kissmyss in forum General Tech Discussion
    Last Post: 05-01-2014, 06:57 PM
  2. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  3. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  4. Bad Axles?
    By lflylow in forum General Tech Discussion
    Last Post: 10-20-2011, 08:57 PM
  5. New CV Axles.
    By Brammer in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2011, 10:06 PM
