Thread: Weird slipping issue
Results 1 to 5 of 5
  1. #1 Weird slipping issue
    Jan 2015
    illinois
    I have a 2004 GTP that's displaying a slipping issue that's kind of unusual.. Compared to the other complaints ive been reading.. My transmission slips when its cold, but after it warm up, it shift fine.. If I start to drive it while cold, it will slip.. But once the transmission temperature rise over 80, it shifts fine.. Sometimes it will slip until it bangs, then once it bangs, its fine for the rest of the day.. If it sits for a while, it goes through this whole process all over again.. Also, if I put my foot on the brake, while revving the engine, then go into drive its fine..
  2. #2 Re: Weird slipping issue
    Sounds like the piston seal to me. Great description of the issue from TEP
    http://tripleedgeperformance.com/No-Forward-Cold.html
  3. #3 Re: Weird slipping issue
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Exactly my issue. And it will get worse quickly if you dont fix it asap.
    Dont try to change fluid and filter it will only make it worse(already tried it)
    I have been having this issue for a year now and it now very bad. Pricing out rebuilds in my area because scared it won't last much longer
  4. #4 Re: Weird slipping issue
    Jan 2015
    havelock, ontario canada
    I have been experiencing a few problems wit my transmition, when accelerating it will hold a gear for a long period of time, even after letting off the gas? It will not shift till about 60 kmph if feathering throttle, when it shifts it drops to 1300 rpm or it will rev up to 4 grand if I still try to moderately accelerate then shifts. If I accelerate quick or drive her hard the time I go to pass someone she cuts out, dies basically looses power 50/50 it stalls and wont start until I turn the key off and open the door?
  5. #5 Re: Weird slipping issue
    St Thomas Ontario
    Not sure of your issue but you should create your own thread about it
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Weird trans slipping...
    By gagt3100 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-12-2013, 09:16 PM
  3. Help! Weird KR Issue
    By wa04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 11:35 PM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
