Thread: dynotech 300m input shaft
Results 1 to 6 of 6
  1. #1 dynotech 300m input shaft
    Kemmerer, Wyoming
    I have a dynotech transmission and it has the dynotech 7/8's chain and 300m input shaft. I have a set of gxp wheels with mickey thompson et streets. when I put those wheels and tires on is it hard launching like at the 1/4 mile that puts more stress on the IS? If I go a little easier on the launch and then go full throttle at like 15 mph will that reduce stress enough to ease my worries? the only person I know of that destroyed the dynotech 300m had a turbo build, so maybe I am being overly cautious.
    xp cam, ported L32 heads, full size phenolic intercooler and a ported gen 3 supercharger.
  2. #2 Re: dynotech 300m input shaft
    May 2008
    Schuyler, NE
    You probably won't make enough power with an m90 to break a 300m. The hardest thing on them, is spinning the tires til they hook. When they hook, that is when most input shafts break. You are way better off dead hooking than spinning.
  3. #3 Re: dynotech 300m input shaft
    Banned
    CT
    Likely only making ~315whp so I'd say a 300m is going to hold up pretty well.
    Although you may have a trashed m90 case if it looks like all the other ported m90s I see on this board.
    Which would mean you're probably making even less than that.
  4. #4 Re: dynotech 300m input shaft
    Kemmerer, Wyoming
    thanks for the input. salsilver2000 or something like that was the one that told me his dynotech 300m snapped on the first launch or shortly after. if I add methanol or nitrous will I be close to the threshold?
  5. #5 Re: dynotech 300m input shaft
    Banned
    CT
    maybe a 100+ shot.. Sal's car is ~500whp.
  6. #6 Re: dynotech 300m input shaft
    Chances are a 300m is going to hold anything a m90 car car throw out.
  1. Dynotech 300m input shaft
    By crbquist in forum For Sale - Parts
    Last Post: 03-23-2015, 09:02 AM
  2. Dynotech input shaft, 1" chain
    By UR LOSN in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2008, 02:30 PM
