I'm not so sure that's the issue. Let's do some more testing.
When you say you have those gears. Do you actually have those gears as you row through the pattern or do you have that showing on the dash as you go through the pattern?
If it's your dash that shows it, search on my name and "ea sy" without the space then find the external pnp switch. Do that and you are fixed up.
If you actually get that going through the gears..then Greg is right and below is what happened to you. You paired the wrong wire with the wrong manual valve.
And..here's how long the combo needs to be.
