Thread: How much can it handle?
Results 1 to 20 of 23
  1. #1 How much can it handle?
    Sep 2014
    Rhode Island
    Hey guys, I was looking through some posts on here and I see a lot about how weak the transmissions are one these cars. I was just wondering if anyone could tell me how much power can the trans on an 06 Grand prix gt supercharged can handle (100k). Thanks.
  2. #2 Re: How much can it handle?
    Hard to say.. Some guys will have tranny problems well before 100k. It's just something that you know can happen and prepare yourself for when it does. I think luck plays a big part as well as how you beat on the car.. Keep the trans temp within reason, don't beat on it and add a shift kit and do a pan drop.
    04 Comp G.
  3. #3 Re: How much can it handle?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    luck plays a huge part IMO, I've seen people pop trannies with a mostly stock setup.. yet I have two friends, one with a stock rebuilt holding up to 330 whp setup and the other with a bone stock 120k mile trans holding up to 400+ whp turbo setup... but those are both ticking time bombs.
    04 GTP -HAI, 1.9 rockers.
  4. #4 Re: How much can it handle?
    Sep 2014
    Rhode Island
    Also, i have the overkill tune. Idk if that effects its reliablility.
  5. #5 Re: How much can it handle?
    A tune will help but don't expect it to save your life.
    04 Comp G.
  6. #6 Re: How much can it handle?
    Sep 2014
    Rhode Island
    How much does a trans cost to rebuild?
  7. #7 Re: How much can it handle?
    Aug 2013
    Sandy, UT
    A lot.
  8. #8 Re: How much can it handle?
    a "built" for HP tranny will run you upwards of 3 grand. if not more depending on some of the parts. good parts aint cheap.
    stock rebuild 1500 to 2000 at your local shop.
  9. #9 Re: How much can it handle?
    Sep 2014
    Rhode Island
    Yay...
  10. #10 Re: How much can it handle?
    Sep 2014
    Rhode Island
    Is there anything i can really do to help prevent it?
  11. #11 Re: How much can it handle?
    yeah, dont put a turbo on it lol
    truth is if you drive it like a adult and dont beat the snot out of it daily every time you fire it up, the trans should last some time.
    turbo's are just tranny killers tho, the way the power comes on is way stronger then a supercharged engine.
  12. #12 Re: How much can it handle?
    Sep 2014
    Rhode Island
    Lol ok. I treat her nicely so i think ill be good. Hah
  13. #13 Re: How much can it handle?
    I'm on a stock trans still.
  14. #14 Re: How much can it handle?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    my trans was 1,400 rebuilt at a very good transmission shop by my house
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  15. #15 Re: How much can it handle?
    Quote Originally Posted by chris99gtp View Post
    your lucky, most are thieves.
  16. #16 Re: How much can it handle?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    what if you can do the rebuild yourself? My dad is an ASE master tech, and a GM pro, what does it cost in parts to build a good tranny?
  17. #17 Re: How much can it handle?
    Mar 2012
    NC
    There's no such thing as a "good" 4T65...you're just extending its detonation time. People have spend a few thousand dollars in parts alone to have one that'll hold up for awhile.
  18. #18 Re: How much can it handle?
    May 2012
    Where winter never ends
    Few things. I am the guy snow was talking about with the turbo setup on a stock trans...
    1) If your smart with how you drive even at WOT it'll last longer than you think but not much past where I am now
    2) A moderate build will run 3-4K
    3) My build has cost me 5-6K and I am doing all the labor by my self.. with labor would have tipped around 8-10k
    I have a 1in GMR Chain (1500$), an Aramet 1200 input shaft (800$), TEP Stage 2 kit (1000), other misc stuff in it
    4) Sven your wrong. If you get a full GMR setup and run 500whp itll last forever.
    5) If you have the resources DIY it.. itll save you a bunch. Get the kit from TEP and go nuts.
    2000 Regal - Winter Beater
  19. #19 Re: How much can it handle?
    Aug 2013
    Sandy, UT
    Quote Originally Posted by adecker View Post
    Aaron not forever, you'll still burn through most of the clutches in 20-40k miles on a 500 whp all gmr setup.
  20. #20 Re: How much can it handle?
    May 2008
    Schuyler, NE
    Get a cartuning or sonnex billet 3rd gear clutch hub, and that will take care of a lot of the problems. But, there are still other things that can break. I've spent years and lots of time acquiring all the trans parts I've got, trying to make it bulletproof...but it's not entirely possible. Sure, you can make it a lot stronger, but not indestructible.
    That being said, I ran a few 11 second passes on a stock transmission, and lots of deep 12 second passes. The guy from Canada went 11.0 on a stock trans as well.
    From what I have found, the best way to keep them alive, is to keep it from spinning and keep the shifts soft.
  1. Why your basic car will never handle...
    Last Post: 01-28-2011, 03:13 AM
  2. How much HP can our 3.8's handle ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-31-2010, 04:32 PM
  3. Need help with a handle
    By thenervemann in forum Visual/Body Modifications
    Last Post: 02-08-2010, 09:31 AM
