You 97-03 Guys would have to use the factory lines and cut them anyway since your fittings have a check valve in them IIRC. And i know the 9c1 setup well since that is what i have. I run full standalone, and have been for years now, It speaks volumes that my GXP made it over 100K with the factory trans while most couldnt make it that far, With you guys im sure the benefits would be even greater.
Exactly.
04+guys didnt get ****ed at all we have no check valves in our line fittings at all, I made a writeup here http://www.grandprixforums.net/threa...ines-*Updated*
we can simply use whatever -6 out the trans case to whatever line and run like that, I have drilled out -6 port to -8 pushlocs on full 1/2 line to the 9c1 oil cooler as a trans cooler. which allows 1/2 fittings as well.
