Thread: Solenoid question
Results 1 to 9 of 9
  1. #1 Solenoid question
    SE Level Member synfullj187's Avatar
    Aug 2014
    I have a 99 GTP and it has 170k. I'm having a shifting issues with my tranny. Some times it won't shift till it gets into really high rpms. Then it also jerks at times. Ive done a fluid and filter change and also used some lucus oil. From what I've read I need some solinoids. But I'm not sure what ones I all need. I don't want to get into it and have wrong ones. Thanks for any help
  2. #2 Re: Solenoid question
    At that many miles, you are better off doing a full rebuild. Likely all the clutch packs aswell as a solenoids are all worn out. I bet even the 4th gear shaft is almost worn thin and soon to strip and be gone at that many miles.
  3. #3 Re: Solenoid question
    Aug 2014
    5FDP rocks first off. And that socks too here that. I figured as much. I was hoping this would do it.
  4. #4 Re: Solenoid question
    I mean you could do the most popular solenoids like the PCS, TCC and do the new 4th gear shaft while you had the side cover off but you have to do so much work to just get that far. And then what if all that doesnt fix it, you still have a trans with over 170,000 miles.
  5. #5 Re: Solenoid question
    Aug 2014
    Yeah. I agree with ya there. It is a lot of work and money.
  6. #6 Re: Solenoid question
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The first place to start would be to have it diagnosed with a scan tool and verify the pcm (computer) is telling the transmission to shift when it is OR if this is actually a mechanical transmission problem. Since these transmissions are electronically controlled they normally only do what the pcm commands them to do. Late and hard shifts can be as simple as a speed sensor or tps sensor causing problems and why it is important to have it properly diagnosed.
  7. #7 Re: Solenoid question
    Aug 2014
    Well It throws codes when it has trouble shifting. It will go to like 4000 then shift . Then some times it clunks into gear. Then it won't do it for awhile. All the wired and pins look good on harness to module.
  8. #8 Re: Solenoid question
    Dec 2012
    Where 4T65E's were born
    Get those codes and that will likely point you in the right direction. But still its got high miles and if a solenoid gets replaced and fixed, something else could go soon anyway.
    Sold.
  9. #9 Re: Solenoid question
    Aug 2014
    Yeah ill probably drive till it quits.
  1. Question about replacing TCC Solenoid (P0742)
    By gtpterp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 08:32 AM
  2. 2001 grand prix solenoid replacement question
    By 01whitegp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 11:44 PM
  3. Epc solenoid Question
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2010, 11:02 PM
  4. Shift solenoid question
    By bretz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2010, 10:52 PM
  5. bypass solenoid question
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2010, 05:51 PM
