Thread: Need transmission help ASAP
Results 1 to 3 of 3
  1. #1 Need transmission help ASAP
    Aug 2013
    illinois
    How do I fix and get rid of these following fault codes
    Fault codes
    P1860 tcc pwm solenoid
    P0758 shift solenoid b
    P0753 power train shift solenoid A
    And if I buy 2 shift solenoid and a tcc solenoid from zzp will that fix my issues?
  2. #2 Re: Need transmission help ASAP
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    These are all electrical codes and will all set at the same time if you have no power going to the transmission. The pcm runs functional and electrical tests on the solenoids. There is a TCC/Transmission fuse in the underhood fuse block so make sure it is not blown. If the fuse checks out OK then you need to verify there is 12v+ ignition feed at the transmission case connector. Inside the transmission this is a common 12v+ feed to all 3 solenoids and why all codes will be present if you lose power.
  3. #3 Re: Need transmission help ASAP
    Aug 2013
    illinois
    Thanks a lot I just checked it this morning and it wa blown so hopefully ityll be fixed now thank you for the help would you recommend a trans flush
  1. 2004 GTP transmission vs GTP Comp G transmission
    By Jordan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2014, 12:33 PM
  2. Need Help ASAP! Please.
    By Grand PrE in forum Off Topic Discussion
    Last Post: 06-03-2011, 02:04 PM
  3. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  4. I need a l67 asap !!!!!!!!
    By hatrain32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 09:25 AM
