Thread: More Trans swap questions
Results 1 to 5 of 5
  1. #1 More Trans swap questions
    Jan 2014
    East Grand Forks
    I have a 99 gt I'm putting a different trans in... I heard 97 to 98 have threaded cooler lines... Mine has threaded cooler lines... And I was told the old owner put in an hd diff... Should I look for a hd trans or regular 4t65e? Will an 02 century trans work? (4t65e) and than change gear ratio in th pcm?
    Sent from my SPH-D710 using Tapatalk
  2. #2 Re: More Trans swap questions
    Check that the century has a 4T65E, IIRC most got the 4T60E for quite a bit longer because they were 3.1L cars vs the 3800 cars.
    If your Diff was swapped that means you are currently running a 3.29 gear ratio. Any non HD 4T65E transmission plus that diff will give you 3.29 ratio. If you dropped in the HD trans and reprogrammed for 2.93, you are likely to need to tweak your timing and shift tables as well.
  3. #3 Re: More Trans swap questions
    GrandPrix Junkie
    Mar 2012
    NC
    You are correct Bill. The Century did have the 4T60 but as of at least 2000 m.y. they were 4T65 cars.
  4. #4 Re: More Trans swap questions
    Jan 2014
    East Grand Forks
    Ok. If the century does have a 4t65. Can I install it and just have a guy change the gearing in he pcm to the 3.09 or what ever the century ratio is and do I quick run to see what it looks like?
  5. #5 Re: More Trans swap questions
    Yeah you could.
  1. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  2. a few more trans questions
    By chrisgsx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2011, 05:05 PM
  3. Just a few trans removal questions
    Last Post: 07-25-2011, 07:12 AM
  4. XAB and XBB trans code questions..
    By 00BLUEPOSGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-25-2011, 07:28 AM
