Thread: 7/8" gear problems.
Results 1 to 8 of 8
  1. #1 7/8" gear problems.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    I recently picked up a used 7/8" setup and the driven gear has damage where the bearing rides. Have any of you guys had a similar issue? Does this look fixable to you guys? I have sent a email to TEP about his thoughts and if he sells the gears separately. Waiting for a response back. His website along with ZZP shows out of stock for the 2.93 sets. I think I may swing by a machine shop tomorrow and see if they can do anything with it.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  2. #2 Re: 7/8" gear problems.
    That looks like rust and bad rust. I agree that you should not put that in looking like that. Also thinking that likely that won't clean up enough to be usable.
  3. #3 Re: 7/8" gear problems.
    Daytona, florida
    Im pretty sure the damage was done by the bearing since the area just above it in picture is perfect. It appears the gears from TEP are backordered and they do not sell them separately. I don't want to run it like that. I think I might run it by a machine shop and see if they have any ideas. Does anyone know what the gears came from before they were machined? 4t60e? Maybe I can get another gear and have It machined by someone.
  4. #4 Re: 7/8" gear problems.
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    They do come from a 4T60E.....Agree with Bill that do NOT run that in your transmission. There is no machine work that is every going to fix that. Very tight tolerance in that caged bearing and by the time you polish that out it will be out of tolerance. I don't think it's caused by rust, but do think it was cause by that caged bearing failing.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: 7/8" gear problems.
    Daytona, florida
    Alright thanks guys. The plan for now is to source a gear from a 4t60E and have it machined locally.
  6. #6 Re: 7/8" gear problems.
    Daytona, florida
    I have a 97 gp gt with a 4t60e that I plan on replacing with a 4t65e hd that I already have. Is there a way to find out what sprocket set it has in it now. It seems to be 3.29 ratio from what I have read but I have not been able to find the number of teeth on the drive and driven gears. I need a 33 tooth driven gear. If that is what I have then I will use that one and have it machined.
  7. #7 Re: 7/8" gear problems.
    Daytona, florida
    Looks like the 97 gp gt 4t60e has 35/35 sprockets so no go on that. I need to try to find a 33 tooth driven sprocket. If no one has one I found one for sale for around $45 online.
  8. #8 Re: 7/8" gear problems.
    Daytona, florida
    Well the one for $45 they were backordered even though they said they had them in stock. The next cheapest one I could find is $69. Man I hope this is the right one and they actually have it. Its frustrating when one little part causes so much trouble to track down. Ah the joys of buying used parts.
  1. "2nd gear start"
    By bjhartogh in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 06-09-2016, 01:49 PM
  2. 1998 Pontiac grand prix,3800 Series 2 "Power Steering Problems"
    By Gchronic in forum Introductions/Noob Questions
    Last Post: 12-04-2012, 08:02 PM
  3. 3rd Gear problems
    By Bessesen2 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-22-2012, 05:47 AM
  4. 4th gear problems
    By uNda6gT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2010, 12:06 PM
  5. Auto 1st gear problems
    By Paulmora08 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-09-2010, 11:48 AM
