Thread: 4th gear problems
Results 1 to 8 of 8
  1. #1 4th gear problems
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    Hey everybody I have a 2002 grand prix gt and I'm on my 2nd tranny,I believe this 1 was rebuilt but not 100% sure,anyway when I'm cruising 1st 2nd and 3rd work fine but when I'm in the top of 3rd gear going into 4th it just stays in 3rd,now if I go Wide Open Throttle it goes into 4th with no problem...anybody have any ideas or suggestions on what it could be? Ay help is appreciated thanks!
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: 4th gear problems
    Jan 2009
    Baltimore
    Anybody???
  3. #3 Re: 4th gear problems
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by uNda6gT View Post
    I think you have no responses because this makes no sense. It's shifting into 4th just fine at 130+ MPH?
    Loosing 4th is very common on transmissions older than 2003, the splines on the clutch hub wear away.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: 4th gear problems
    Right on with Doug. Makes little sense that the TPS must be working properly to shift the other gears and 4th should drop in easily with low throttle. Yet a WOT or even a 80% throttle should keep you out of 4th.
    May be worthy to check your TPS just in case.
  5. #5 Re: 4th gear problems
    Jan 2009
    Baltimore
    TPS?????
    so how exactly could i tell if its the 4th gear shaft?
  6. #6 Re: 4th gear problems
    QCA, IA
    TPS is throttle position sensor. The computer uses it to know when to shift.
    First off, is it shifting into 4th at all or not? If not, it's a very good bet that it's the clutch hub.
  7. #7 Re: 4th gear problems
    Jan 2009
    Baltimore
    Quote Originally Posted by Scimmia View Post
    well this is the thing when i cruise it goes thru 1st gear,then 2nd gear then 3rd but it never goes into 4th but if im just cruising @ the top of 3rd and then just mash on the gas it feels like it went into 4th....i know it sounds weird but idk
  8. #8 Re: 4th gear problems
    My thoughts is the best advice we can give you is to head for a trans shop and ask them to diagnose it. Seems as though you might not have a lot of experience with trans issues, which is making the internet diagnosis tough.
  1. no first gear what gives
    By blacksleeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2010, 07:49 PM
  2. rev gear bad.
    By clevelandfan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2010, 12:48 AM
  3. Auto 1st gear problems
    By Paulmora08 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-09-2010, 11:48 AM
  4. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
