View Poll Results: What is your normal trans temp daily driving?
Voters
14. You may not vote on this poll
  • Less then 180
    3 21.43%
  • Between 180 - 190
    3 21.43%
  • Between 190 - 200
    5 35.71%
  • More then 200
    3 21.43%
Thread: 04+ Trans Temp (Daily Driving)
Results 21 to 40 of 70
  1. #21 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    This ends hopefully after today
  2. #22 Re: 04+ Trans Temp (Daily Driving)
    GTP Level Member
    Aug 2012
    st louis park, MN
    Good lord that is warm for daily driving.
  3. #23 Re: 04+ Trans Temp (Daily Driving)
    Arizona
    Here you go 174 trans temp 102 ambient
  4. #24 Re: 04+ Trans Temp (Daily Driving)
    SWPA
    You ended up going with a plate and bar cooler didn't you?
    Highest I saw today was 183*. It was about 85* at the time. I am ran in series and I ran the car hard just to see what it would do. The coolant temp was climbing a little so that may have been a bigger factor than anything.
    I plan to watch the temps on Thursday's road trip. If they get too hot I plan on swapping over to stand alone. I don't care what the manufacturer's say, I still think stand alone will be more effecient.
  5. #25 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    167 on the way home started at 108 so not bad. I checked for leaks and the lines are bone dry quite content at this point
  6. #26 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    Any reason why I would seem like my cooler isn't cooling
  7. #27 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    It also seems to retain heat. I'll check fluid levels for the 3rd time later and the lines aren't leaking
  8. #28 Re: 04+ Trans Temp (Daily Driving)
    Aug 2011
    'Merica
    Mine did this..........emphasis on did. We all know the end of the story.
  9. #29 Re: 04+ Trans Temp (Daily Driving)
    Yoga city
    how you get the plastic out? I wanna clean the dust out of mine.
    Quote Originally Posted by 91parkave View Post
  10. #30 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    Quote Originally Posted by Below Average Joe View Post
    Have a clue why mine restauned heat all night
  11. #31 Re: 04+ Trans Temp (Daily Driving)
    Aug 2011
    'Merica
    Not sure. Install is pretty straight forward. Maybe too small of a cooler.
  12. #32 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    28000 gvw
  13. #33 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    And it's in series. I'll check fluid level and for kinks today after work
  14. #34 Re: 04+ Trans Temp (Daily Driving)
    Aug 2011
    'Merica
    Mine is only 22000gvw. Take some pics if you can.
  15. #35 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    I will after work around 3 today
  16. #36 Re: 04+ Trans Temp (Daily Driving)
    Aug 2011
    'Merica
    ok.
  17. #37 Re: 04+ Trans Temp (Daily Driving)
    Arizona
    Tube and fin coolers will usually do that. Especially wjen you have trans fluid that gets baked in a radiator trans cooler first.
    THIS IS WHY I PREACH STANDALONE!
    Quote Originally Posted by jteske88 View Post
    I need to redo mine you have to take it completley apart then use a heat gun and pry the plastic off
  18. #38 Re: 04+ Trans Temp (Daily Driving)
    Aug 2011
    'Merica
    What do you mean by standalone? Just have the cooler do all of the work and not run the lines into the rad at all? If so, this is what we did with mine.
  19. #39 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    You didn't get to me quick enough!! I'll make it stand alone if I start having more issues
    Edit. Also I made it run through the tube and fin cooler first
  20. #40 Re: 04+ Trans Temp (Daily Driving)
    SWPA
    That's where you went wrong. You should have cut the return line if you were running in series.
  1. Trans Temp too low?
    By Linebacker in forum General Tech Discussion
    Last Post: 11-13-2013, 09:00 AM
  2. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
  3. Streetable Radial Setup for Daily driving
    By gagt3100 in forum Tires & Wheels
    Last Post: 01-01-2013, 11:20 PM
  4. Temp fluctuates a lot city driving
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2012, 08:46 PM
  5. trans temp
    Last Post: 04-28-2009, 11:13 AM
