Thread: p0717 and p0716 any advice
Results 1 to 3 of 3
  1. #1 p0717 and p0716 any advice
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    If you dont know what these codes stand for they are P0717 Input Speed Sensor Low Input and p0716 input turbine sensor parameters out of range. If anyone has advice it would be much appreciated. The car does not show any signs of problems. I had these codes come up last summer but cleared them I checked my dtc the today and saw they came back but not sure how long they have been on there.
  2. #2 Re: p0717 and p0716 any advice
    Check the speed sensor on the tranny, check all the wires.
    Likely the circut is open at times, meaning a kink or break in the wires.
  3. #3 Re: p0717 and p0716 any advice
    The input relates to the sensor buried inside the trans. I don't see the issue being the vehicle speed sensor located on the tailshaft, only because of too much experience and reading up on ISS codes. Since you were able to clear it before..I'd check the wiring going from pcm to trans
  1. P0716 & P0717 Code after Rebuild. Searching for right gear. Sometimes wont go into OD
    By DnaProdigy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-18-2013, 12:10 PM
  2. Trans issues...P0716 and P0717
    By mykp13 in forum Midwest
    Last Post: 05-18-2012, 08:44 AM
  3. Need Help/Advice/Suggestions on 4T65E-HD (MYSTERY OF P0717 TROUBLE CODE)
    By Bulletproof Gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2011, 11:01 AM
  4. P0716 & p0717
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2011, 05:55 PM
  5. p0717, p0716, What fixes this
    By Jambat1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2010, 10:57 AM
