02NavyBlue
03 and up has the hardened 4th splines he means ^
You have the 4t65e-hd since you have a GTP. If it's supercharged then it's a hd trans.
If the 4th clutch hub splines strip, you will never go back into overdrive until it's replaced. Also the earliest 4th gear will ever apply is at 45+ so anything below it will be third unless you go past and slowly decel it will stay a bit below 45.
