Thread: Transmission axle shaft??? maybe called output shaft.
Results 1 to 4 of 4
  1. #1 Transmission axle shaft??? maybe called output shaft.
    Nov 2013
    lville
    so i am doing the solenoids on a 2006 grand prix 3.8 sc 4t65e-hd tranny. i have the side case open and i noticed that the shaft that connect to the c/v axle has some play in it.... it this ok or something else really wrong?
  2. #2 Re: Transmission axle shaft??? maybe called output shaft.
    Has play left and right and some up and down correct?
    That should be normal, as when the CV shaft goes into the tranny it will center it.
  3. #3 Re: Transmission axle shaft??? maybe called output shaft.
    Nov 2013
    lville
    that is correct. I guess Im being paranoid... thanks for the help!
  4. #4 Re: Transmission axle shaft??? maybe called output shaft.
    Sloppy is normal in these transmissions. You should see the parts behind the case cover aka channel plate before the 4th thingee goes in place. Sloppy mess
  1. output shaft comes out
    By zach101 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2013, 03:04 PM
  2. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  3. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
