Thread: 270,000 Mile Pan Drop ... Brass Pieces?
Results 1 to 9 of 9
  1. #1 270,000 Mile Pan Drop ... Brass Pieces?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Good day all,
    I hit 270,000 miles in my GTP the week before last. Completed a number of service items today, including the transmission fluid/filter.
    Went the extra step and busted open the old filter. Have some pictures for y'all.
    Notice the circular pieces that appear to be brass... some kind of bearing maybe? Thoughts?
    I'm hoping to milk this drivetrain (all original) to 300,000 miles.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    Does it still shift fine?
  3. #3 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    only one way to find out. keep driving it. more then likely what ever that is has been there for a long time.
    the magnet looks damn clean and the fluid looks a touch dark but not to bad really for those miles.
  4. #4 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    HUDSON
    Those brass pieces look like the thrust washers for the planet gears on the differential.
  5. #5 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    Knoxville, TN
    Yes, the shifting is still fine, considering the mileage. The torque converter engagement is rather harsh though. This is due to raising the TCC duty cycle in the PCM. Without a raised TCC duty cycle, I have an issue with RPM's oscillating when the transmission warms up.
    Scottydoggs
    Well, this isn't my first pan drop in this car. I did this around 230,000 and 250,000 as well. The level of metal in the magnet is about the same at each interval. I've been using Dexron 6 since I bought the vehicle. I know that Dex 6 is visually darker than Dex 3. Still dark for Dex 6?
    QUICKSILVER462
    Hmm, maybe. I'd say the brass pieces are a few times thicker than a sheet of paper, but definitely seem like more of a foil/shaving than a piece of a washer. It's hard to tell from my photos, though.
  6. #6 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    HUDSON
    It is thin as foil because it has been worn down, maybe it has a lot of mile on it.
  7. #7 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by QUICKSILVER462 View Post
    This ^^^^ I wouldnt say specifically the planets on the diff, but that definitely looks like pieces of planetary gear thrust washer. Something is wore out
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  8. #8 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    Knoxville, TN
    Quote Originally Posted by Anthony Smith View Post
    Does this mean that I'm likely to lose one or more of my gears very soon?
  9. #9 Re: 270,000 Mile Pan Drop ... Brass Pieces?
    Not necessarily. The washers are obviously in there to keep the steel from wearing the other steel etc. If it's not diff and it's planetary like Anthony mentioned, it's dead center of a trans. I'd drive it til it drops.
  1. 04 front drop-in strut pieces?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2014, 09:00 AM
  2. Headlight Pieces
    By MattF in forum Wanted To Buy - Parts
    Last Post: 01-06-2014, 07:22 PM
