Thread: valve body channel plate removal/torque specs photo
Results 1 to 6 of 6
  1. #1 valve body channel plate removal/torque specs photo
    Apr 2014
    CT
    I made myself a photo showing bolt sizes and torque specs for removing channel plate/valve body as one assembly. I figured I would share it for anyone that needs it. ( I grabbed the photo off this forum by Twizted 1).
  2. #2 Re: valve body channel plate removal/torque specs photo
    Apr 2014
    CT
    damn it I just realized I screwed up the two pump bolts Ill have to fix it.
  3. #3 Re: valve body channel plate removal/torque specs photo
    Dec 2012
    Where 4T65E's were born
    Twizted 1 posted it if you'd like to credit it.
    Sold.
  4. #4 Re: valve body channel plate removal/torque specs photo
    Apr 2014
    CT
    thanks.
  5. #5 Re: valve body channel plate removal/torque specs photo
    Pennsylvania, USA
    As a side note to anyone with an 05, so maybe 04-08 inclusive, my pump didn't have the bolt that holds it together. No spot exists on the pump, not sure why. It came out in one piece in spite of it, so the design may have changed at some point.
  6. #6 Re: valve body channel plate removal/torque specs photo
    They changed the design, you swap the entire pump instead of rebuilding it.
  1. Channel plate bearing
    By Jevik in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2013, 10:27 PM
  2. Channel plate gasket
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2012, 08:27 PM
  3. Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
    By Overboost in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2012, 04:54 PM
  4. find 4t65e channel plate checkball location
    By rlevand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 08:51 PM
  5. channel plate input shaft sleeve scored.. HELP!
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 10:43 PM
