Thread: trouble putting vb back on
Results 1 to 8 of 8
  1. #1 trouble putting vb back on
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    My valve body won't go back on after installing 4th clutch hub. it will go down on the side the fourth clutch hub is on but wont go down on the side that the torque converter input shaft is on. It's about 1cm away from seating how it should. Any ideas on why it would be doing this?
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: trouble putting vb back on
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    There is a bushing that goes in between the channel plate and the drive sprocket. It has 3 little tabs on it and if it falls out of place while trying to install it will cause what you're describing. Also make sure that you reluctor wheel is fully seated into the sprockets. Use petrolem jelly to keep that bushing glued to the channel plate so it stays right where it's supposed to during the install.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: trouble putting vb back on
    Jan 2012
    Indianapolis
    I took the bushing off and still had the same problem.
    I'm at a loss. I'll have to . Post a video of the issue and maybe get some more ideas
  4. #4 Re: trouble putting vb back on
    Apr 2011
    Columbus, OH
    Did you also take out the 2nd clutch drum and Input/3rd drum? Are you doing a rebuild or did you only do this to get the valve body off? Need a little more information to be able to help you out.
    I have a trans torn down right now....tonight I'll be putting the channel plate and valve body back on.
  5. #5 Re: trouble putting vb back on
    Jan 2012
    Indianapolis
    I didn't pull anything other than the valve body and then I switched out the 4th clutch hub with a new one. I did try to pull some of the other stuff below the clutch hub out of the case just cuz i'm nosy but it didn't move so I just figured I'd leave that alone. It's getting hung up on the opposite side of that tho so I don't think that caused the issue.
    I did pull the input gears up because I thought it would make replacing the input shaft/torque converter seal easier without the shaft in but I'm pretty positive it re-seated properly when I put it back in. I turned that thing every which way and pushed down to make sure. Unless there is some special sort of re-seating procedure I'm sure its in
    The tranny is out of the vehicle incase that matters.
  6. #6 Re: trouble putting vb back on
    Apr 2011
    Columbus, OH
    Ok, there is also a thrust washer that goes on the back side of the 4th hub and sits into the driven sprocket.....There are 4 little tabs no it that have to align and go into that sprocket. If not it will make that 4th hub sit up higher than it's supposed to and also cause that side of the channel plate to not fully seat properly.
  7. #7 Re: trouble putting vb back on
    Apr 2011
    Columbus, OH
    Just to also verify here....are you talking about JUST the valve body or are you talking about the Channel Plate also??
  8. #8 Re: trouble putting vb back on
    Jan 2012
    Indianapolis
    The thrust washer is going on right. It's definitely an issue with hanging up on the opposite side. Not on the side the 4th clutch hub is on.
    I am talking about the channel plate and valve body. I probably should have mentioned that to begin with.
  1. fuel pump having trouble putting back in...
    By ajc549FF in forum General Tech Discussion
    Last Post: 01-31-2012, 08:36 PM
  2. So, putting engine back together after cam install
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:25 AM
  3. Putting Factory Stereo Back In 2000 gp
    By MysticStyl3z in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 03:51 PM
  4. Car wont run after putting SC back in
    By funky4stringed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2010, 10:13 PM
  5. Putting front end back togeather
    By Ineverfollow in forum General Tech Discussion
    Last Post: 12-15-2009, 03:46 AM
