Thread: Trans Fluid Question
Results 1 to 6 of 6
  1. #1 Trans Fluid Question
    Dec 2013
    Indiana
    I'm getting ready to change the transmission fluid in my daughters 2008 Grand Prix with 67,000 miles on it. Is the Valvoline Max Life fluid ok to use in my application where it calls for Dexron VI? The reason I ask is because the actual Valvoline Dexron VI fluid is like $7.50 a quart and I can get the Max Life for $16.48 a gallon.
  2. #2 Re: Trans Fluid Question
    i bought my tranny fluid at tractor supply, it was like $30 for a 2 gallon jug. you need 8 quarts.
    walmart fluid is the same as travelers brand what tractor supply sells.
  3. #3 Re: Trans Fluid Question
    Dec 2012
    Where 4T65E's were born
    You should use Dexron VI in 2006 + gm cars. I'm sure III will work but in 2006 VI was the fluid that was put in from the factory. It is a better fluid in theory.
    Sold.
  4. #4 Re: Trans Fluid Question
    Oct 2013
    NC
    I would stick with Dexron VI based on the change interval requirements.
    Sent from my SCH-I535 using Tapatalk
  5. #5 Re: Trans Fluid Question
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    The Valvoline Maxlife Dexmerc is approved for Dex VI applications, I'm using it in my 06 DD right now along with some lucas.
  6. #6 Re: Trans Fluid Question
    New York
    I use Walmart Super Tech Dexron VI in my 01 GP-150,000 miles on the tranny now. My car calls for Dexron III and Dexron VI is backwards compatible. Sure appears to be the case. Tranny is perfect!
  1. Question checking trans fluid level
    By jasonnovak in forum General Tech Discussion
    Last Post: 12-23-2013, 06:39 PM
  2. Trans fluid help!
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-29-2013, 12:17 PM
  3. Trans and fluid question....
    By GoldGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-29-2012, 12:14 PM
  4. 05 prix comp edition trans fluid temp question
    By tznitup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2011, 12:40 AM
  5. I guess a newb question about trans fluid
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2008, 02:00 AM
