There's plenty of upgrades you could do if you were having one built.
I'd start off with saying TEP would likely be your best builder. They take the time to talk to you and understand your ideas/goals then match trans upgrades etc to your build. I'm not aware of many others that do that.
In that case, I'd automatically say.. look at your tire size and how much % it's different than stock and consider making up some of that with a gear ratio change. Afterall the manufacturer uses many different variables in building our cars and the biggest single things they do in the trans to mediate less power, larger tire size, etc are torque converter stall and gear ratio.
Is this something that could be addressed in a custom dyno tune?
