Thread: Need some Transmission Repair Advice - Lost Drive and 3rd
Results 1 to 20 of 22
  1. #1 Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    I've only posted a few times here because I'm very keen on utilizing the search function on this great forum. Since owning my 2002 Grand Prix GTP since December 2012, I've had just about every common issue come up with these and have been able to fix them pretty easily. I've had the steering rack leak, water in the floorboard, keys stuck, shifter stuck in park, P0102 code, so on and so forth. Outside of the rack, these were all really quick, easy fixes and expected for a car with nearly 150k miles. I'm afraid that is likely no longer the case.
    My current problem, as the title states, is that my transmission had Drive and 3rd go out yesterday, unceremoniously to say the least. There was no thud, no whine, no slip, no SES code, nothing. Simply turned the car back on in the parking lot and she didn't engage into drive at all. There has been no obvious issues with the transmission before this. I still have reverse, 2nd, and 1st working so I was able to get it home. I first thought it was something electrical, given how sudden and unexpected it happened. But, as I continued to read, BillBoost had posted elsewhere that leads me to believe it is a broken forward band rather confidently.
    I am pretty schooled on everything car related except for transmissions. I believe a diagnostic test runs about $50 locally, but with what I've read, I'm about 98% sure its the forward band issue. I know anything transmission related is serious money. Is it worth repairing or replacing? What should I be planning on spending? Should I expect a decent car life after either or more problems down the road? Sorry for the silly questions, but I literally have never had trans issues on a car.
    Any information that can help me make a sound, educated decision moving forward will be really appreciated!
  2. #2 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    does sound like the forward band broke.
    used is the cheap way. and if your up to it, the labor is free. search craigslist for part outs in your area. most run 400 or less.
  3. #3 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Agreed, that is a classic symptom of a forward band.
  4. #4 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    Thanks guys! Took it in to a reputable transmission shop today to get a diagnostic done. It will only cost me $50 and I'll know 100% what is wrong. I'll let you know what they find, but I'm pretty confident after reading that it is the forward band.
  5. #5 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    Well, you boys were indeed right. Just got a call from the shop and they want $3,000 for install of a re-manufactured! After some preliminary searching, I may have serious issues finding a JY one locally being that I'm in Central Illinois. Any additional direction on this headache would be appreciated.
  6. #6 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by dlofx View Post
    Rip off. You can get a new triple edge trans for less than that. Run as far away from that shop as you can. A standard rebuild with installation at a reputable shop should be no more than $2000.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  7. #7 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Nov 2008
    Central NJ
    I just replaced my trans by myself this past November with some help and pointers from guys on this site. My trans was slipping and I got a price of over $2400 to rebuild mine from Aamco. I went the junk yard route and found a trans with half of the miles I had on my failing trans.
    Quick summary:
    Used trans...$475 with 67k miles
    Fluid and filter and a few misc parts...$100
    I already put 16k miles on it in 8 months
    No problems at all
  8. #8 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    So, I took the advice of others and attempted to source a few local junk yards for a transmission with some sort of warranty. After checking out every place within about 50 miles of me, I have turned up 1 transmission and they're asking over $1,000 for it! Seems asinine. Unfortunately, I live in Central Illinois and this ain't Chicago.
    Any idea on what a 2002 GTP is worth in its current condition, knowing I only have reverse, first, and second right now and that is likely to go? Just about at the point of moving on right now.
  9. #9 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    I'd give you $300...
    Try Car-Part.com It shouldn't be that diffucult.
  10. #10 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    And you might of just saved my car! There's a yard within 10 miles of me with one. If this checks out, I owe you big time sir!
  11. #11 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I bought a damn near new one from my local pullapart for $107.
    I would go to their website and find one close to you.
    You'll have to pull a Bunch of pans to find a good one but it's WELL worth it
  12. #12 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    Okay, so it all checks out! Found a decent deal (relative to my location) for a transmission and am picking it up tomorrow.
    Outside of the trans, what items will I be needing and any additional you would recommend? I'm guessing fluid and filter, but anything else? I will not be doing it myself, have a friend that has done one and will be compensating him for his time.
  13. #13 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    toss a shift kit in the tranny when you do the pan drop.
    depending on the year of the tranny, if its a 97-02-or 03 even, you may want to change the 4 th gear hub since it will be out of the car. this new part costs around 70 bucks, and fixes the ive lost 4 th gear problem the older trannys have. the newer trannys came with this new part.
  14. #14 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Jul 2013
    Richmond, VA
    Late to the party here but doesn't TEP have a rebuilt with no core charge for $14xx shipped?
  15. #15 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    JY transmission is in and the car is once again running! Appreciate the advice guys.
    Now on to troubleshooting why the SES light went on afterwards for a P0102. Guessing it was unrelated, just not timely. Hoping to catch a break with this thing!
  16. #16 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    check the wires to the maf, and check the fuse boxes, theres a fuse for the maf somewhere. if that all checks out, get a jy maf.
    you do the swap yourself?
  17. #17 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    Thanks for the advice! I used MAF cleaner last night, cleared the code and it stayed off for 3 separate trips. Granted this is off topic, but any input on the MAF sensors on Ebay? My JY wants $65 and they're $40 on Ebay. It just kicked back on today at lunch. I just want to get rid of the lights on the dashboard like you have personally experienced. My SES, SRS, ABS, TCS, and fuel sending unit are wreaking havoc on my mental state right now, lol. All of which I have found some response to on here. The new fuel sending unit went out within 4 months. I am beginning to wonder if it is an electrical issue.
    As for the transmission, I assisted in it but really was there to see the process and learn mostly. I did compensate a friend and his brother for their time, but am rationalizing it as a 'learning experience'. Pan was really clean except for a huge chunk of metal, consistent with what was likely the forward band you mentioned. All totaled, it took about a day and a half. With a lift, it would have been half that time. The real challenge was navigating the removal in a 1.5 car garage with a ton of tools and junk. For the sake of time, I ended up skipping the shift kit cause I was down my main mode of transportation and would have had to wait for shipping. I installed a new filter and fluid after seeing that it was low in the JY one. So far, so good.
  18. #18 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    if you buy a maf off ebay, make sure its a oem maf, not a after market one, these cars tend to hate after market mafs for some reason.
    or if you got a you pull it JY, pocket the maf, and smile on the way out lol
  19. #19 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    gardner,mass
    ^ lol Look on rockauto.com
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  20. #20 Re: Need some Transmission Repair Advice - Lost Drive and 3rd
    Dec 2012
    Illinois
    Quote Originally Posted by Ginseng View Post
    Any experience with the Dorman off of there?
  1. 98 grand prix transmission repair questions
    By vtechkiller in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-10-2013, 06:43 AM
  2. Transmission doesnt drive in any gear.
    By legend in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-29-2011, 07:36 AM
  3. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  4. lost of power need good advice
    By mtz956 in forum General Tech Discussion
    Last Post: 12-26-2010, 10:03 PM
  5. Transmission repair guidance
    By cwgruv3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 04:21 PM
