Thread: Transmission fluid and filter.
Results 1 to 3 of 3
  1. #1 Transmission fluid and filter.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    So my 02 GP GT has ~145k and it has never had any transmission service, yes I know, bad owner
    However, I figured I might as well try to make up for my past mistakes and go ahead and drop the pan and change the fluid and filter. I've done the work on other cars before, but for this car should that transmission pan gasket still be good or should I go ahead and order a new one from the dealer?
  2. #2 Re: Transmission fluid and filter.
    clean the stock gasket with brake cleaner wipe it off reuse it.
    clean the pan and magnet real good too. brake cleaner also. buying 2 cans is always the way to go cause one is never enough lol
    sh it goes fast lol
  3. #3 Re: Transmission fluid and filter.
    Easy way to tell if it's original gasket. It'll have metal in it and ribs on the surface. Wipe clean and reuse that gasket. If it's a thin rubber w/o any rigidity..put the new gasket on it.
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  3. Trans Fluid/filter
    By Pshnmeawy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2011, 08:43 AM
  4. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  5. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
