Thread: Axle leak
Results 1 to 16 of 16
  1. #1 Axle leak
    Jan 2009
    Tallahassee, FL
    I had a leak from the driver side axle. I replaced the seal and thought that would solve the issue, well I was wrong. It still leaks. What I need to know is that are there any other seals that could leak and look like an axle seal, the fluid is definitely coming from the seal area though. Also if the axle shaft is worn what is the correct size of the axle to determine if it is undersized or not?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Axle leak
    search dirtdogs ride thread, iirc he had the same problem, i think he found out the seals are different size store brand to store brand. one worked one did not.
  3. #3 Re: Axle leak
    That was a passenger IIRC.
  4. #4 Re: Axle leak
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I got tired of having leaks on both sides so I install axle stabilizers. They are a bearing/seal combo that stop vibrations as well as leaks.
    Although yours could be leaking from the laser cut side cover seal. You'll need to clean it good and watch it closely to see where its coming from.
  5. #5 Re: Axle leak
    Jan 2009
    Tallahassee, FL
    I'll have to look into those, never heard of them before.
    I'm pretty sure it's the axle seal, there is fluid pooled in the lip that's outside/around the seal.
    edit:
    Where did you get those? I can't find them.
    77 Morris Garage B
  6. #6 Re: Axle leak
    St. Louis
    Try here. First place I found using the part # on the bag in the pic above.
    http://www.transmissionpartsusa.com/...-075125lrb.htm
  7. #7 Re: Axle leak
    Feb 2013
    37.295091, -121.930053
    i see a part number in the picture
    part # 75125LRB
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Axle leak
    Jul 2013
    Summertown Tn
    Here's the left side
    http://www.teckpak-fitzall.com/spgm.cfm?id=84125LB
    Here's the right side that is shown in the picture. http://www.teckpak-fitzall.com/spgm.cfm?id=75125LRB
  9. #9 Re: Axle leak
    Jan 2009
    Tallahassee, FL
    Thanks guys
    So are these really worth it over the regular seals?
    I still want to know the axle OD so I can make sure that its not the problem first.
    77 Morris Garage B
  10. #10 Re: Axle leak
    Jul 2013
    Summertown Tn
    In my opinion YES. I haven't had a leak since I installed them.
    It took all of the wobble out of the axle as well.
  11. #11 Re: Axle leak
    Jan 2009
    Tallahassee, FL
    Now if they say went bad, how hard would they be to get out in the car?
    77 Morris Garage B
  12. #12 Re: Axle leak
    Jul 2013
    Summertown Tn
    If what went bad? The fitzall bearing/seal? Cant answer that question because ive never had one go bad.
    As far as getting the axles out I think it makes them easier to remove.
    IF the bearing/seal goes bad for some reason I don't think it would be any harder to get them out as it would to get a regular seal out.
  13. #13 Re: Axle leak
    Jan 2009
    Tallahassee, FL
    I bit the bullet and ordered one to try it out.
    77 Morris Garage B
  14. #14 Re: Axle leak
    Jul 2013
    Summertown Tn
    Be sure to follow the instructions that come with it. Go to a machine shop and get some fine grit Emory cloth. You'll need it to sand the rust and dirt off the axle where the new bearing will ride.
    I'm sure you wont be disappointed.
  15. #15 Re: Axle leak
    Jan 2009
    Tallahassee, FL
    So I got this thing installed and it seems like everything is good. My only concern is that is this thing supposed to install flush or not? I kept tapping it in till it wouldn't go in anymore but there is about 1/16"-1/8" before the lip would fully seat.
    77 Morris Garage B
  16. #16 Re: Axle leak
    Jul 2013
    Summertown Tn
    It has splines on it that cut into the housing to hold it in place. Mine has the small gap as we'll but has never caused any problems.
    Reptile DHP ecm, ported SC, ported and blocked LIM, SD headers, 1.9 Harland sharp rockers, HAI
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. axle
    By tylersgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2010, 07:35 PM
