Thread: Mystery Trans Piece, found in pan.....What is it??
Results 1 to 9 of 9
  1. #1 Mystery Trans Piece, found in pan.....What is it??
    Sep 2012
    MI
    So did a tran pan drop, and found this inside the pan. What is it?
  2. #2 Re: Mystery Trans Piece, found in pan.....What is it??
    I live here. DirtDog's Avatar
    Jun 2012
    Well I'm no expert but....that shouldn't be there
  3. #3 Re: Mystery Trans Piece, found in pan.....What is it??
    First time dropping the pan on the car?
    Likely its a piece off the assembly line for the trans, helps keep somthing from moving or falling out on its way through the build process, alot of vehicles will have a small plastic piece resting in the bottom when the pan comes off as it can't get through the filter.
  4. #4 Re: Mystery Trans Piece, found in pan.....What is it??
    Cam.. are you talking about? I've never found a piece of plastic commonly in the pan on a first drop.
    How big is this piece? I've had ever piece and part out of a trans.. that's not looking familiar at all.
  5. #5 Re: Mystery Trans Piece, found in pan.....What is it??
    Sep 2012
    MI
    The piece is made of plastic and about 1/2" square. this is the first time i have dropped the pan, bought the car used.
  6. #6 Re: Mystery Trans Piece, found in pan.....What is it??
    Feb 2013
    37.295091, -121.930053
    Almost looks like a relay or sensor
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Mystery Trans Piece, found in pan.....What is it??
    Eh, fords are really common with plugs or plastic caps for the fill tubes, prehaps this trans has been serviced before your ownership and was just left in the pan.
    Or my other guess of something from the assembly, I mean like how many of these transmission where made..... over one hundred thousand atleast.
  8. #8 Re: Mystery Trans Piece, found in pan.....What is it??
    Sep 2012
    MI
    I though maybe at cap to a solinoid or something like that. Well atleast i know the pans clean now. Thanks for the replys.
  9. #9 Re: Mystery Trans Piece, found in pan.....What is it??
    Cam.. you don't mean normal part from assembly, you are talking some er uh.. Mon/Fri thing?
    I guess. There's not much plastic normally in there. A few flat bushings, the lube dam or lube slinger whatever the couple of them are called. None seem to resemble that part though.
  1. 2000 GTP Mystery
    By addeible in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2013, 10:49 PM
  2. mystery gas smell
    By asite57 in forum General Tech Discussion
    Last Post: 04-20-2012, 10:50 AM
  3. Oil line mystery
    By 62duoglide in forum General Tech Discussion
    Last Post: 04-12-2011, 05:14 PM
  4. Replaced trans filter and look what i found
    By 99GPGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2010, 04:38 PM
  5. Found This Joke. Also Found It Amusing.
    Last Post: 12-05-2008, 04:25 AM
