So I had a mild slip when cold but today its slipping all the time and started leaking a lot of fluid and smoking while driving. How f'd am i?
Step one, fix known issues. Did you tear the diff in half and it was slipping, then it cracked the case?
You aren't changing that gear ratio easily. That would require pulling the side cover.
Ok good cause I want the 3.29s. But is it worth upgrading to hd kit? Idk car has been slipping cold start up on take off normal driving but yesterday I was a dumbass pissed of and gave it some throttle and next thing I know I'm smoking get home look under the car and there's a chunk missing from the dif case.
