if the filter is clogged up it usually due to a parts coming a part. like gears shredding and letting shards of metal loose in the fluid, the filter picks it up, and it clogs.
when you drop the pan theres a magnet under the filter, if theres metal in the fluid some will be trapped on the magnet. you'll know more once the pan is off.
