Thread: No 3rd gear upshift
Results 1 to 6 of 6
  1. #1 No 3rd gear upshift
    Aug 2013
    mpls, mn
    1-2 is fine. Rev to 4k, let off throttle and she shifts fine into OD. If I give it gas, at say 50mph, it will downshift fine into 3rd but will go back to OD as soon as I go to part throttle. Dropped pan, checked accum pistons.look fine. O-rings are ok, center shafts are tight, no slop. So, I yanked trans and stuck in another unit. My car is 99 gt and has 9BCB trans tag. Got a trans from 99 venture which also has 9BCB tag. Car shifts Fine with new trans. But I am curious to open up old trans and see what's up.
  2. #2 Re: No 3rd gear upshift
    you lost 3 rd gear, time for a rebuild or a used one swapped in.
    i am also a member of the i lost 3 rd gear club. it sucks. used tranny was the fix.
  3. #3 Re: No 3rd gear upshift
    Aug 2013
    mpls, mn
    Other threads say 3rd gear sprag. And burnt band.
  4. #4 Re: No 3rd gear upshift
    when you just pop the shiftier to 3 rd when at highway speed its kinda in neutral, when you give it gas it needs enough to power second gear, and its a lot like you know.
    i drove for a good month like that, then drove it 2 hours to get swapped out. you dont even think about passing on the highway either lol
  5. #5 Re: No 3rd gear upshift
    There isn't a band for 3rd only. The forward band works all forward gears. Likely it's a broken sprag or cooked third clutches. If you pull it apart, I'd think you'll find a ton of slop in the 3rd/input housing on the clutch packs.
  6. #6 Re: No 3rd gear upshift
    Aug 2013
    mpls, mn
    been told if 3rd is gone, than i should not have 4th. i can drive all day in 4th just fine. i did see a slight variation in tach on 100 mile drive to dads shop. seemed to waver 100 rpm or so occasionally. but, old trans is out and sitting in corner.
  1. gear set, 4th gear hub, channel plate gouged! help!
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 04:54 AM
  2. Wont upshift 2-3 but down shifts 4-3
    By bstuby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2011, 08:40 AM
  3. Max engine torque for upshift
    By Juanmiguel in forum PCM Tuning
    Last Post: 05-15-2011, 02:27 PM
  4. Newb Question about 4th gear upshift
    By mtcimpala in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2009, 07:38 PM
  5. 1974 Upshift??
    By 74GrandPrix in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 08-09-2009, 03:28 PM
