Thread: Yet another hard shift question, lol
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: Yet another hard shift question, lol
    Oh..and if you go in for the EPC.. You might as well fix the 4th clutch hub.
  2. #2 Re: Yet another hard shift question, lol
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    thanks guys, i think i'll go with the shift kit. I have an automotive background so it should be a breeze.
    whats up with the 4th clutch hub? is that a common thing? still new here to the 4t65e lol
  3. #3 Re: Yet another hard shift question, lol
    97-02 (and early production 03) had a non hardened 4th clutch hub. So the splines wear and you lose 4th at some point. That point is a moving target though..I've had many 180K+ 4T65's that had 4th gear w/o any issues. The replacement part is a heat treated aka hardened part.
    On that shift kit. Drop your 20 10mm pan bolts, pull a few 8mm bolts and the accumulator is in your hands. Pull a few more 8mm's and a few minutes the kit it in and you are putting the accumulator back in the car. Toss in your new filter and the pan. Refill.. done.
  4. #4 Re: Yet another hard shift question, lol
    Jun 2013
    London, Ontario
    my car is an 04, still replace the 4th clutch hub if i do the ECS?
  5. #5 Re: Yet another hard shift question, lol
    Nops.. being a 04, it has teh hardened shaft.
  6. #6 Re: Yet another hard shift question, lol
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Shift kit is a piece of cake!! I did mine a couple weeks back. Piece of cake and my trans loves me for it!!! Go TransGo. it's great for daily driving with the occasional WOT runs!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  7. #7 Re: Yet another hard shift question, lol
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    instead of all this downshift talk, i have a question, ive had bad luck on both my GP's, both GTP and ever since i bought the car from my buddy, it shifts hard into 4th, like you can watch the rpms go up with the clutch opens and then the car will jerk and you can feel it as it shifts, its a big shift, no codes, not a big annoyance but obviously not normal, any ideas?
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  8. #8 Re: Yet another hard shift question, lol
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    is it cause the TC locks as soon as it shifts when you're cruising around 1.8k rpms
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  9. #9 Re: Yet another hard shift question, lol
    Mar 2013
    Fort Lauderdale, FL
    Quote Originally Posted by JDrach View Post
    hmm, well it doesnt bother me too much but another thing i just experienced tonight, driving from a stop and... only.. sometimes.. shifting into 2nd, it is a harder shift but then different pressure of gas and it will shift into 2nd very smooth and same with 3rd. so im thinking fluid maybe for starters. cause on my first gtp, i flushed the fluid cause it was shifting weird into 2nd as well but it was like a wobbly bouncing continuing shift as for this is just a hard shift, after i flushed it, it never did it again
    1998 GTP Loudmouth
  1. 0 RPM hard shift
    By Logan541 in forum General Tech Discussion
    Last Post: 08-17-2012, 12:41 PM
  2. Hard shift issue
    By 7point62 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 08:00 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
  5. hard shift between 1rst and 2nd
    By gp2004_compg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 06:56 PM
